New owner with ?
Old Nov 13, 2009 | 04:41 AM
jasonlouis2217's Avatar
jasonlouis2217
Default New owner with ?
Just recently purchased my first vette - '97 c5, Carmine red, auto, both targa tops, blk leather, 40k mi for 16.5k. My ? I can hear a metal on metal clanking from the rear susp. when i hit bumps, I think its the 12 yr old bushings. Is it, and if so which ones, and is it a diy job? Thanks for any help. Finally no longer just a member but also an owner!!!!!
Old Nov 13, 2009 | 06:44 AM
Can't help you with the diagnosis, but congrats on getting into a C5. Post up a pic when you can.
Old Nov 13, 2009 | 06:52 AM
DeeGee's Avatar
DeeGee
It could be sway bar bushings and that's a DIY fix
Search for sway bars and you should find a guide. I'll post a link if I can find one.
Old Nov 14, 2009 | 08:12 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
My suggestion will be to jack it up put it on some JACKSTANDS and do a thurough inspection - grabbing parts, shaking them doing some impact work with a "HEAVY" RUBBER Mallet!
Take a close look at the ENDLINKS in the back since they are Plastic and not metal - it is very possible they can be shot!
Thanks,Matt
Old Nov 14, 2009 | 08:36 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Congrats on your Vette and end links are most likely the issue
Old Nov 14, 2009 | 09:01 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Don't rule out the exhaust as the source of your noise in the rear. 40,000 miles is a little early for suspension problems even though it's a 12 year old car. Congrats on your Vette
Old Nov 14, 2009 | 09:38 AM
vette.mix's Avatar
vette.mix
Congrats on your Vette, probably end links like most say
Old Nov 14, 2009 | 11:20 AM
tlc0706's Avatar
tlc0706
Thanks,Matt
Congratulations on becoming a Vette owner.....
Old Nov 14, 2009 | 11:30 AM
rebelheart's Avatar
rebelheart
Congrats on your new car and I agree, you should look at your sway bar end links!
Old Nov 14, 2009 | 11:32 AM
Silver48's Avatar
Silver48
Pictures, Pictures......we want Pictures!
Old Nov 14, 2009 | 11:40 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
I wager its the swaybar bushings or possibly the end links. either way seems like a good time to upgrade to some new bars, end links and bushings. lots of options. I upgraded to c6 z51 bars.
good luck with the fix and congrats on the vette
To New owner with ?
