Changing The Oil
Old Nov 19, 2009 | 08:31 PM
Slow Z06's Avatar
Slow Z06
Default Changing The Oil
Running some Oreilly 10w30 oil. Got 60 miles on it. Time to change. Got me some new 10w30 and a new WIX filter. Whoo hoo.......
Come on next oil change
Old Nov 19, 2009 | 08:37 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
hows the new motor?
Old Nov 19, 2009 | 08:39 PM
Oldvetter's Avatar
Oldvetter
Is this Oreilly Oil synthetic? I know it doesn't meet the GM "Corvette Specification", I would not use it.
Wait, 60 miles and Twin Turbo ! Are you breaking in a new motor?
Old Nov 19, 2009 | 08:47 PM
Slow Z06's Avatar
Slow Z06
Motor is coming along nicely. Got one more dino oil change then I can go synth and get it on a dyno for tuning.
Old Nov 19, 2009 | 08:52 PM
JJ 86's Avatar
JJ 86
Awesome! Anxiously awaiting new HP/TQ #'s...
Old Nov 19, 2009 | 08:54 PM
mojo1's Avatar
mojo1
Sweet , !
Old Nov 19, 2009 | 11:54 PM
Looking forward to hearing about the power numbers from the new motor.
Old Nov 20, 2009 | 01:21 AM
itzza427's Avatar
itzza427
Man you REALLY like to flirt with the flame throwers mentioning regular oil in a C5 (without an explanation that is,,and even then some will say STILL use synthetic)!! Keep us posted!!
Old Nov 20, 2009 | 07:43 AM
rws.1's Avatar
rws.1
I'm new school....
use synthetic when breaking in a new engine.....
Old Nov 20, 2009 | 11:10 AM
Slow Z06's Avatar
Slow Z06
eh i considered using new, but older is cheaper and no need to fix a system thats not broken.
Old Nov 20, 2009 | 03:11 PM
SFL_driver's Avatar
SFL_driver
I always use mobil 1 no exceptions
Old Nov 21, 2009 | 06:10 AM
Patman's Avatar
Patman
Originally Posted by rws.1
I'm new school....
If it was a factory fresh engine, yes, but not one that was rebuilt. A rebuild is going to have a few more "contaminents" in it such as dust and cam lube, etc. So you want to do a lot more frequent changes on an engine like that (such as doing the first change after just a day or two, and then the second one a few hundred miles later) So there is no sense in wasting $$$ on expensive synthetic during this process. Running a conventional oil for a couple of weeks is not going to shorten the life of the engine at all anyhow. Just don't go do anything that would elevate the oil temps above 220F for any length of time while you're running the conventional oil.
Old Nov 21, 2009 | 06:36 AM
csexton's Avatar
csexton
Enjoy that new power
Chuck
Old Nov 21, 2009 | 04:18 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is exactly how I broke in my engine 4 years ago, dyno oil and 3 changes in 200 miles and then to the good stuff
Old Nov 21, 2009 | 04:35 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Jerry,
Dont switch to synthetic for at least 2500 miles. With your high tension rings, the synthetic will immediatly stop ALL break in. But the organic oil will continue to allow the rings to seat.
Running regular oil will cost you about 10rwhp on the dyno, but I have seen it a million times. The guy switches to synthetic, then begins complaining he has oil consumption and/or blow by. Alot of times this is because he switches over to a synthetic based oil to soon.
Seriously, as an engine builder, it is not something we EVER reccomend. There is 100 different theories on how to seat the rings. But when it comes to oil use, safe is ALWAYS better.
After about 2500 miles, then, and only then, switch to synthetic.
Our reccomended break-in is as follows:
  • Joe Gibbs Break in oil 10/30 with high ZDDP, and filter for 30 minutes. Then change filter.
  • Change oil/Filter again at 2 hours, or 150 miles
  • Joe Gibbs break in oil with high ZDDP and new filter for additional 250 miles. Then change oil/filter
  • Regular 10/30 and good filter for additional 2000 miles. At 2000 miles, check your oil consumption. if you are fine, then switch to synthetic. If not, run hard to 3000 miles. Then swap to synthetic regardless.
    This is our required break in for our customers motors.
    OE rings, OE replacements, and alot of the low tension rings have extremely fast break in periods. But the moly steel rings dont break in that easy.
Old Nov 21, 2009 | 05:32 PM
Slow Z06's Avatar
Slow Z06
Thanks for the advice Jeff!!
Old Nov 21, 2009 | 08:47 PM
beary58's Avatar
beary58
Yes, I actually stay with non synthetic for 5000 miles. I have not owned a new car with synthetic yet, but if I did, I would drain it and put in non synthetic. I just don't trust using synthetic for something as important as break in.
Beary
To Changing The Oil
Old Nov 21, 2009 | 09:10 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Nice problem to have!
Hope the new engine was by choice and not by neccessity!
Old Nov 21, 2009 | 11:24 PM
rebelheart's Avatar
rebelheart
Ponders how all these Corvettes ever broke in with synthetic oil from the factory...... I would worry more about the dino oil baking and coking from the extreme heat of the turbos more than anything!
Old Nov 22, 2009 | 07:14 AM
Patman's Avatar
Patman
It's explained above, the OE rings seat very quickly even with synthetic oil, but with aftermarket high tension rings they need to stay away from synthetic at first for proper break in.
