Spares for a C5?
Old Nov 19, 2009 | 11:31 PM
Jack Daniels's Avatar
Jack Daniels
Default Spares for a C5?
I have a C5 and just ordered non-runflats. I know there are tire repair kits, but I really want a spare
I think 2004 and up GTO spares will work, but they are pretty hard to come by I am told.
Will aNything else work? Like a Cavalier or Cobalt or Malibu spare?
Old Nov 19, 2009 | 11:41 PM
2KROADSTER's Avatar
2KROADSTER
I'd say forget the idea of a spare (plus tools to remove tire). My spare is AAA Motor Club. Sure takes up a lot less room in the trunk.
Old Nov 19, 2009 | 11:43 PM
Here was some info that was posted on the forum a long time ago. Supposedly this worked for the forum member.
On our last mountain cruise, a Z06 got a flat tire and tried to fix it with the Z06 flat fix kit. It didn't work worth a damn. Luckily we had a few C4s on the cruise and the C4 spare, jack, and lug wrench worked perfectly for the 50-mile ride home.
This incident gave me an idea and I created my own C5 spare tire kit for my Coupe since I plan on going to non-runflats. I bought a 17" C4 space saver spare tire, C4 lug wrench & a C4 jack (all used) for $80. I started with a 4x4 piece of 1/2 inch particle board (plywood would be lighter) and cut it to fit around the glass top holder mounts in the rear hatch area. I covered the wood with dark gray carpet from Home Depot (didn't have black). I drilled 3 holes and mounted the spare with carriage bolts. It fits tight in the back and doesn't move around at all. It takes up very little room and I only plan to use it on trips and cruises. When I don’t use it, I can hang it on the wall in my garage so it's out of the way.
Hope this helps.
Old Nov 20, 2009 | 12:27 AM
JETZ's Avatar
JETZ
I've seen pics of Jag wheels on C5's.
Old Nov 20, 2009 | 06:51 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I use an old rim and just chunk it in for long trips, takes up a lot of space but its worth it to me, also have the compressor and tire plugs.
Old Nov 20, 2009 | 08:00 AM
Bills03Coupe's Avatar
Bills03Coupe
I recall reading a warning about using an undersized spare on the rear of a C5 or C6 Corvette. It can damage the differential if driven for more then a few miles.
Old Nov 20, 2009 | 09:12 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Been running non-runflats for the last 100K miles. I have had 2 flats both times while on the highway, TPS warned me of a low tire pulled over and hooked up the pump found the nail or screw pulled & plugged in less than 10 minutes and on my way. I later had the tire patched on the inside.
What I carry
1 C4 jack (just in case it goes flat & I need to raise the car to find the culprit)
2 air pump
3 plug kit (not the one with cheep tools) get a good kit if you have to use it its worth it.
4 A small tool kit.
Old Nov 23, 2009 | 12:18 AM
Jack Daniels
Shoot, the differential thing worries me---can anyone confirm its a problem if you drive it for more than just a few miles?
NIce to know a C4 spare rim actually fits it--would be great if it didn't destroy the differential
Old Nov 23, 2009 | 01:43 AM
DeeGee's Avatar
DeeGee
Thats a new one. Any links?
Old Nov 23, 2009 | 09:08 AM
Bills03Coupe
I don't have a link, but from what I recall the difference in the outside diameter of the GTO spare compared to the standard size wheel causes undue stress on the positraction clutches, causing them to slip excessively. Driving too far or too fast will fry the clutches. It also will likely negatively effect active handling and the ABS system.
Old Nov 23, 2009 | 11:38 AM
joshtownsend's Avatar
joshtownsend
GTO and C4 spares are the same size in diameter..or very close and vetteman said he drove 50 miles and didn’t report any issues... that’s real world testing right there...
A better solution would be to make friends with a C4 owner and make sure he goes everywhere you do!!! hahaha
Old Jan 7, 2010 | 10:10 PM
bobette's Avatar
bobette
there is a spare tire kit from vettespare
Old Jan 13, 2010 | 01:06 AM
Jack Daniels
Thanks bobbette. While a little pricey, looks good.
Is it safe to say it will not ruin the differential? I can't tell the rim size.
Old Jan 13, 2010 | 01:07 AM
Jack Daniels
I see they claim less risk of differential damage than runflats...
Old Jan 13, 2010 | 01:09 AM
HowlinC5's Avatar
HowlinC5
I know that f-bodies have the same lug pattern, in fact my f-body spare has been on a vette before.
Old Jan 13, 2010 | 01:21 AM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
It was discussed some in this old series of posts
http://forums.corvetteforum.com/c5-t...re-for-c5.html
Old Jan 13, 2010 | 08:45 AM
4theboy's Avatar
4theboy
From what I understand the real problem with a C4 spare is that nobody makes a spare tire to fit the C4 spare rims anymore.
To Spares for a C5?
Old Jan 13, 2010 | 09:24 AM
jrose7004's Avatar
jrose7004
I used a cell phone and a AAA membership.
Old Jan 13, 2010 | 10:05 AM
Sinister-one's Avatar
Sinister-one
and where would someone carry this spare tire ??
I carry a Z06 flat kit less the sealant. I have a plug kit in there instead of the sealant.
Old Jan 13, 2010 | 10:24 AM
Fast Cop's Avatar
Fast Cop
I carry a can of the tire sealant in my car. Just in case.
