tire sizes vs traction control issues
Old Nov 20, 2009 | 10:05 AM
DeBaGo's Avatar
DeBaGo
Default tire sizes vs traction control issues
I am putting stock 275/40/18's on the rear, but before I put the 245/45/17 on the front again I just wanted to see if i can go wider without screwing up the traction control.
I would ideally like 275 all around.
Old Nov 20, 2009 | 02:25 PM
mickey_7106's Avatar
mickey_7106
i think its only if you go over 1" diameter between the front and back that TC starts going off..dont think it matters how wide the tires are
Old Nov 20, 2009 | 03:03 PM
steve8's Avatar
steve8
Stock Z is a 265 on the front, so I wouldn't think a 275 is a problem, but I don't know for sure. You want to have at least 1/2" difference in height for the TC.
Old Nov 20, 2009 | 04:03 PM
AU N EGL's Avatar
AU N EGL
many ppl run 275s or wider on the front. Just have the rear slighty wider and taller then the front tires 1/2" will do and no AH/TC problems
Old Nov 20, 2009 | 04:13 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can go wider but not in Diameter - it will cause issues, if you decide to go over or under the 1" buffer then you will need your PCM tuned to accept the new dimension
Thanks,Matt
To tire sizes vs traction control issues
