Dumb Question, but....
Old Nov 20, 2009 | 05:01 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default Dumb Question, but....
...why do C5's (I am assuming that it is particular to C5's) have so much difficulty with the fuel gauge? I have run into it and treated it with Techron and now only use Exxon gas, but can't wonder why this is an issue. I know some of the issues with sulphur deposits, but why only with the vette? I guess I am asking what is the fundamental engineering problem that needs to be fixed, the sending unit, the gauge,...?
I haved owned and currently own a vast array of other cars and none seem to have had this issue. I always took the fuel gauge operating correctly as a given in todays automotive environment and I am perlexed that the vette would have this type of an issue.
Old Nov 20, 2009 | 05:07 PM
DARRYLZO6's Avatar
DARRYLZO6
Its not a dumb question. Inoperable fuel gauges on C5 is pretty common like ABS sensors are common too among other things. sometimes the fuel pump has too be replaced. Sometimes.
Old Nov 20, 2009 | 05:45 PM
65GGvert's Avatar
65GGvert
It happens a lot, but nearly as much as it sounds like when you read the forum. Remember, for every one you read about, there are thousands that don't have a problem. I've had two and have never seen the fuel gauge or oil pressure sensor, or the rear end leak. I don't think I'm lucky, I think the majority don't have the problem.
Old Nov 20, 2009 | 06:00 PM
alxltd1's Avatar
alxltd1
I can appreciate that the amount of those having problems will be more than those not, as most dont post just to say nothing is wrong. But mine did have the problem and I am looking to find root cause and maybe apply a permanent fix. As an example, if it is the sending unit I would look to replace the sending unit with a better alternative (if one existed) rather than replace it with one of the same. Just seems that adding Techron every so many tankfuls is treating the symptom rather than the cause. But I understand your point.
Old Nov 20, 2009 | 06:10 PM
65GGvert's Avatar
65GGvert
The problem is that the sending unit is inside the tank and in the fuel. I think that's a bad idea, but it's the way it is. The only fix for sure is to replace the sending unit. I don't know of any improved unit available, but if someone has one, I think they can make good money. The Techron helps clean of the deposits on the rheostat part of the sending unit so that it makes better contact to read the position of the sensor. Personally, I think keeping the tank full all the time increases the likelihood of seeing the problem. Running down to a lower amount and refilling forces the movement of the sensor and therefore helps keep it from becoming coated. I can't prove it, so take it for what it is.
Old Nov 20, 2009 | 06:31 PM
Cybermind's Avatar
Cybermind
I always thought it was the other way around. You should keep the gas tank full at all times to keep everything submerged. Aren't deposits formed when a liquid is allowed to evaporate and thus leaving behind contaminants and undiluted chemicals? I may be wrong but I was always under this assumption. It does make sense though.
Old Nov 20, 2009 | 07:14 PM
smiley callender's Avatar
smiley callender
I replaced my sending unit over 5 years ago and no more problems. I too use techron about every 3rd tank. I think more people are having problems with the sender and not the gage.My opinion.
Old Nov 20, 2009 | 11:40 PM
napacruzerc5's Avatar
napacruzerc5
I seem to get the problem if I let the vette sit too long with a near empty tank.
Old Nov 21, 2009 | 12:38 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I seen it often with GM vehicles around the C5 years, so its not a rare occurance.
Old Nov 21, 2009 | 01:10 AM
GHL4505's Avatar
GHL4505
I've owned two C5's. Both have had the gas gauge problem. I only use Chevron fuel. But, of course don't know what the previous owners used. Both cars had less than 18k miles on them at the time of the problem. I remember cruising on the freeway in my Jeep, when a C5 passed by. I looked over and noticed his dash also had the red low fuel warning light on. Maybe he was just running low on gas, maybe not. I'm guessing for those that haven't had that problem . . . it's only a matter of time. I'm in California and my brother lives in Oregan. His low mileage 03 Z06 also had the gas gauge problem. Hmmmm! I've owned alot of cars and trucks over the 45 years that I've been driving. My two C5's where the only cars that had a gas gauge problem.
Old Nov 21, 2009 | 01:57 AM
lucky99's Avatar
lucky99
Its a GM thing, Truck, Grand Prix, and a Buick all have had gas gauge problems.
Old Nov 21, 2009 | 02:07 AM
striper's Avatar
striper
I also had the problem with my 2000 S-10 pickup. Not with my two C5's though.
Old Nov 21, 2009 | 02:28 AM
DeeGee's Avatar
DeeGee
That makes sense to me but I've always run mine at least 1/4 full and the senders sit quite low in the tank.
I had my first problem 4 years ago in Vegas. I used Techron and it was fine until a few months ago. I had one glitch when I ran the tank very low to get to a gas station that sold 98 octane. the most recent example, I still had nearly 1/2 a tank. No consistency. I found on both occasions recently that if I top the tank off it starts working again. As a precaution I've added Techron each time. I've also switched to Shell V Power gas.
If it becomes a regular problem I'll have to bite the bullet and change the sender.
Here's a pic of the sender that RJ1AZ kindly posted. You can see the offending pick offs that get corroded or contaminated.
His post is worth a read
http://forums.corvetteforum.com/show....php?t=2027250
Old Nov 21, 2009 | 03:22 PM
alxltd1's Avatar
alxltd1
So it seems that the consensus opinion is that it is the sending unit that causes the problem, though there is still debate as to why.
However, just replacing the sending unit with another from GM would seem to mean that it will only again go bad over time. But without an aftermarket alternative, or unless the new units from GM are improved, there is no other option. I would wonder if anyone has ever converted another make sending unit or even an alternative set up, say outside the tank?
Oh well until there is another option I will continue to run Techron through it on occassion. Thanks for all the info.
Old Nov 22, 2009 | 11:38 PM
El original's Avatar
El original
I recall some years ago Shell lost a class action lawsuit with Chrysler/Dodge owners over just such issues, gummed up fuel sending units. So you see, it is not the fuel sending units that are the problem...but the fuel. Hence, certian gas suppliers seem to fix the problem. Others are the problem. Stay away from suspect suppliers eg. Shell gas. Rob
Old Nov 23, 2009 | 06:30 AM
Cybermind's Avatar
Cybermind
You should stick to the Top Tier gas suppliers only. If you do a search on Google, you will find the listing. The gas is supposed to contain added cleaning agents and low sulphur.
Old Nov 23, 2009 | 08:31 AM
Jim2003's Avatar
Jim2003
To Dumb Question, but....
Old Nov 23, 2009 | 09:33 AM
rebelheart's Avatar
rebelheart
I tis the fuel,not the sending units!We had to replace literally hundreds at my dealership(Chrysler/Jeep) for the same problem.The Toyota and Ford stores next door had the same issues.
Old Nov 23, 2009 | 09:37 AM
DeeGee's Avatar
DeeGee
I think were drifting into symptom vs cause here
The sulfur in the gas clogs up the sender
Either way Techron usually fixes it.
Old Nov 23, 2009 | 10:01 AM
itzza427's Avatar
itzza427
IMO Techron IS treating the root problem.I drive mine all the time,thus the float is always moving,,I only run top tier gas(including Shell 93 octane V power) and a few times a year add extra Techron. So far not even a HINT of a problem(Knock on wood)!!I agree that just from reading many post on this a very common factor seems to be cars that are not driven,,,SITTING with less than full tanks, MAY very well be a contributing factor. Not often are these problems reported on cars that are on the move on a very frequent basis. Just an observation,,not a researched fact though!! Add Techron,,,and drive on!!
