Are all x pipes created equal
Old Nov 21, 2009 | 07:15 AM
foundvettelifeisgood's Avatar
Default Are all x pipes created equal
Looks like the Borla x pipe is the least expensive stainless one out there. Typically around $240. Corsa and others around $330 or so. In the pics, the Borla x looks like a small slit at the x point. Is the Borla x as good as the others?
Old Nov 21, 2009 | 07:17 AM
vette.mix's Avatar
vette.mix
Old Nov 21, 2009 | 07:40 AM
Cybermind's Avatar
Cybermind
From what I've read, there are no significant functional differences between aftermarket x pipes. I would go for the best looking one at the cheapest price. Any one you buy will definitely be an improvement over the OEM h-pipe. I personally like the Magnaflow version. But I think I am slightly biased.
Old Nov 21, 2009 | 07:48 AM
AU N EGL's Avatar
AU N EGL
go with the one that has the smoothest lines or transition between each pipe.
Depending on where you mount the x-pipe will have slight power / tq differences
Mount the x-pipe right behind the cats, and a bit more HP, mount the x-pipe right before the over axle pipes( a bit farther back) more low end tq
Good luck
Default Magnaflow
It would appear to be a much larger flow area at the X.
Old Nov 21, 2009 | 08:32 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Get a true X-Pipe, like the one above,
Others are just two merged pipes with a open area between them and then welded together...
Peace
Chip
__________________
..................Click for
Old Nov 21, 2009 | 08:37 AM
AU N EGL's Avatar
AU N EGL
Chip those are the ones you want.
The ones with just the two pipes merged together and welded. Those the X-pipes that produce more power.
PPl can do what they want, it is only a few pones or foot lbs anyway
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
I had the Bassani on mine and I LOVED it! I now have the American Racing 3" X.
Old Nov 21, 2009 | 08:46 AM
CCA Corvette Parts
I agree with you for bigger HP builds where back pressure and savaging is an issue for max power, guess I should have clairified...
Bolt on cars are pretty much just for sound...which is better on a true x
Peace
Chip
Old Nov 21, 2009 | 09:03 AM
I ran a Bassani X-pipe on my '00 - very well made piece and did a great job of eliminating my popping and resonance.
Old Nov 21, 2009 | 09:05 AM
DevilMan02's Avatar
DevilMan02
short answer, they're all equal. buy the cheapest one. You're not going to find one that gives you a 500hp gain.
I have the borla straight pipes (catback) and xpipe. With only that on a stock 02 C5 I put down 310rwhp and 315rwtq SAE corrected on a Mustang Dyno. Those are very conservative numbers.
Old Nov 21, 2009 | 10:54 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The true merged X pipes will do a better job of balancing exhaust pulses between banks giving a moderate scavenging effect lower RPMs. Bassinni (sp), WCC and Magniflow all make this version. I"m running the WCC version on my car.
Old Nov 21, 2009 | 11:14 AM
AU N EGL's Avatar
AU N EGL
Gotcha Chip
Old Nov 21, 2009 | 12:19 PM
jrose7004's Avatar
jrose7004
I always get the x-pipe that is made for the catback that I have.
Old Nov 21, 2009 | 11:30 PM
itzza427's Avatar
itzza427
I have Corsa cat back,,and bought a Corsa X recently. Not out of loyalty or any thing,,just got a like new one for $150 from a buddy that got a new full header system a couple of hundred miles after he got the X installed!!
Old Nov 22, 2009 | 12:14 AM
css12's Avatar
css12
Would it depend on if you've got headers or plan on getting them? I've got kooks on my car, and their custom x-pipe looks like the only thing that will fit on the bottom....
if not, let me know, cuz I really don't want to bust $850 on the catted-x pipe unless I have to.
To Are all x pipes created equal
