P0650 code? what does this mean
Old Nov 22, 2009 | 08:03 PM
jiujitsu77's Avatar
jiujitsu77
Default P0650 code? what does this mean
I just removed my Blackwing air filter for cleaning. when I started the motor it ran funny like it was trying to die. i checked the codes and got a PCM code P0650. could it be that there is oil from the filter on the Mass A/F sensor? what may be causing this?
Old Nov 22, 2009 | 08:47 PM
Carcass's Avatar
Carcass
Looks like its a problem with the "Check Engine" light circuit:
http://www.gearchatter.com/viewpost14396.php
Old Nov 23, 2009 | 02:37 AM
DeeGee's Avatar
DeeGee
Its an unusual one. As its a voltage issue, did you disturb a connector or crimp a wire while you were working?
Cant see why playing with the filter would cause the symptom but the experts may chime in. It may be worth checking in C5 Tech.
Heres the diagnostics with a few connectors to check
Document ID# 671853
2002 Chevrolet Corvette
DTC P0650
Circuit Description
A voltage is supplied directly to the malfunction indicator lamp (MIL). The powertrain control module (PCM) controls the lamp by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line which is monitored by the PCM. When the PCM is commanding a component ON, the voltage of the control circuit should be low, near 0 volts. When the PCM is commanding the control circuit to a component OFF, the voltage potential of the circuit should be high, near the battery voltage. If the fault detection circuit senses a voltage other than what is expected, the fault line status will change causing the DTC to set.
Conditions for Running the DTC
* The engine speed is greater than 400 RPM.
* The ignition voltage ranges between 6-18 volts.
Conditions for Setting the DTC
* The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
* All above conditions exist for a minimum of 5 seconds.
Action Taken When the DTC Sets
* The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
* The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
* The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
* A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
* A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
* Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
* Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing or replacing the module. Verify that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM.
* For any test that requires probing the PCM or probing a component harness connector, use the connector test adapter kit J 35616-A . Using this kit prevents damage to the harness or component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
* If the ignition feed circuit is suspected of being open, verify that the other indicators on that circuit illuminate.
* For an intermittent condition, refer to Intermittent Conditions .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2.
Command both the ON and the OFF states. Repeat the commands as necessary.
8.
If you do not find trouble in the control circuit or the connection at the PCM, the PCM may be faulty. However, this is an extremely unlikely failure.
Step
Action
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Important
If the I/P is completely inoperative, refer to Diagnostic System Check - Instrument Cluster in Instrument Panel, Gauges, and Console.
1. Turn ON the ignition leaving the engine OFF.
2. Command the lamp ON and OFF using the scan tool.
Does the lamp turn ON and OFF with each command?
Go to Diagnostic Aids
Go to Step 3
3
1. Turn OFF the ignition.
2. Disconnect the PCM connector C2. Refer to Powertrain Control Module (PCM) Replacement .
3. Turn ON the ignition.
Is the lamp OFF?
Go to Step 4
Go to Step 5
4
Important
If the fuse opens in the fused jumper wire, repair the circuit for a short to voltage.
Probe the lamp control circuit in the PCM harness connector with a fused jumper wire connected to ground. Refer to Using Fused Jumper Wires in Wiring Systems.
Is the lamp ON?
Go to Step 6
Go to Step 7
5
Repair the short to ground in the lamp control circuit. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
Go to Step 9
6
1. Inspect for a poor connection at the PCM connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
2. If you find a poor connection, repair the connection as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Did you find and correct the condition?
Go to Step 9
Go to Step 8
7
1. Inspect for the following conditions:
* A faulty indicator
* An open ignition feed to the indicator
* A control circuit that is open or shorted to B+
2. Refer to Wiring Repairs in Wiring Systems.
Go to Step 9
8
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Did you complete the replacement?
Go to Step 9
9
1. Use a scan tool in order to clear the DTCs.
2. Turn OFF the ignition for 30 seconds.
3. Start the engine.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run, and pass?
Go to Step 10
Go to Step 2
10
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Document ID# 671853
To P0650 code? what does this mean
