[Z06] Audible "Thunk" Upon Braking
Old Nov 23, 2009 | 08:23 AM
cole925's Avatar
cole925
Default Audible "Thunk" Upon Braking
Need some help guys.
There is a moderately loud "thunk" that happens only sometimes when I brake. I did some basic diagnostics and found out that it is not caused by extreme acceleration or deceleration. Instead, I am fairly sure it is from going over road obstructions (manhole covers, small holes, etc.).
The strange part is that the "thunk" resets itself every time I brake. For instance, say I run over a manhole cover, the next time I brake, guaranteed, the noise occurs. From then on, however, there will be no noise until I jossle the rear end around again. Wash, rinse, repeat....
It sounds like it is happening directly to the rear of the driver's seat, but I can't tell exactly how far back....
Any known culprits?????
Old Nov 23, 2009 | 08:30 AM
AU N EGL's Avatar
AU N EGL
take the wheels off and inspect the brakes. Look for loose parts.
Old Nov 23, 2009 | 09:00 AM
bmg's Avatar
bmg
I would check the rear upper shock mounts and make sure they are torqued to spec.
Old Nov 23, 2009 | 06:23 PM
cole925's Avatar
cole925
Took the rear wheels off... to my dismay, no loose bolts or fasteners. The shocks are definitely not causing it. I did a full undercarriage inspection, no foreign objects. I'm gonna take it out for a spin later tonight, you know how sometimes these things just kinda fix themselves randomly.
Old Nov 24, 2009 | 09:48 AM
cole925's Avatar
cole925
DAMN!!!!
It is still happening as of this morning. It really starting pissing me off, so I did a 100% brake from 70 to 0. The "thunk" started up after another 3 or 4 miles.
Old Nov 24, 2009 | 11:00 AM
bmg's Avatar
bmg
I would still retorque your rear upper shock mounts. How do the sway bar end link bushings look?
Old Nov 24, 2009 | 11:18 AM
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
I've been getting a random sound that sounds SIMILAR to this... but mine sounds more like a caliper hanging up and not releasing the pads when I let off the pedal on the front.
During a few autocrosses, I got a random thunk as well but wouldn't always do it on back to back runs.
The front end is getting gone over this weekend now that the season is over. Checking the sway bar end links ( HD heim joint style ) and also checking for binding of the swaybar itself.
Checking all the brake caliper bolts, connections...
Have to look at the shock mounts as well and double check those. Although the car will be getting new shocks in the coming months and it's about done driving for the winter.
Let us know what you find out!
Old Nov 24, 2009 | 11:40 AM
AU N EGL's Avatar
AU N EGL
Do you have something loose in one of the rear compartments in the truck ?
Old Nov 24, 2009 | 12:23 PM
speedyhawk101's Avatar
speedyhawk101
seat is loose?
Old Nov 24, 2009 | 02:25 PM
cole925's Avatar
cole925
Noted, will do this tonight. I THINK the bushings look fine, but then again I am used to working on my offroad truck, so my margin of error on bushings may not be up to snuff. I'll double check though....
HAHA, you know, I thought I was a complete moron when this first started because I had stuff in the back. I slowly took out one thing after another until there was nothing left. When the sound was still there i started losing my mind/temper......
You think a caliper could be hanging up in the rear? The car only has 30K miles on it, so I don't think the calipers should be shot yet...
Old Nov 24, 2009 | 03:19 PM
billla's Avatar
billla
St. Jude Donor '14
I have exactly this same issue and haven't had time to look yet - this weekend.
Another suggestion was lubricating the outer splines on the half-shafts; search will turn up a bunch of stuff on this and I plan to do it this weekend as well.
Old Nov 24, 2009 | 04:56 PM
AverageVetteNut
No.. sorry I should've clarified mine a bit better. MY FRONT cailper might be hanging up, and that's one of the possible things I was looking at with a clunk coming from mine, and was just something I thought about.
I originally didn't see that you stated that your thunk was from the rear. My apologies.
Old Nov 26, 2009 | 04:28 PM
stas's Avatar
stas
Default had something similar..
I had a clunk originating from a rear caliper. The noise would occur time to time under light breaking before a complete stop. All hardware was tightened properly.. The caliper however felt very loose.. What I did was got some caliper lube (synthetic kind, I think it was by permatex), took the caliper off, cleaned the caliper pins and put a good amount of lube on them and the bolts. Torqued everything to spec again, and that god rid of the noise.. Planning to do something similar to my other wheels.
Stas.
Old Nov 28, 2009 | 03:45 PM
cole925's Avatar
cole925
Alright guys, I think I may have figured it out. When I started it up today, I blipped the throttle to put it in 1st, lo and behold, THE NOISE!!! It sounded exactly like I was going over a bump or applying light brake pressure. Immediately following this the engine RPM's dropped to around 400 and the exhaust sounded muffled (excessive and abnormally quiet). I'm thinking it is something with the exhaust. Are the baffles known to cause problems in the Ti's?? Anybody ever had problems with your own?
Outer splines... as in where the half shafts connect to the hub? That hadn't even crossed my mind. Good suggestion.
To Audible "Thunk" Upon Braking
