Cat removal
Old Nov 23, 2009 | 10:58 AM
markcvechko's Avatar
markcvechko
Default Cat removal
Where do you find cat replacement exhaust for a 2001 and will this throw any codes if I remove them. Live in West Virginia they do not check emmisions
Old Nov 23, 2009 | 10:59 AM
dougbfresh's Avatar
dougbfresh
You don't find one, you have to tune things out after you install whatever pipe your adding to remove the cat. Waste of time.
Old Nov 23, 2009 | 11:12 AM
markcvechko
So what you are saying if I remove the cats the exhaust will sound the same and no codes will show ?
Old Nov 23, 2009 | 11:15 AM
dougbfresh's Avatar
dougbfresh
That's not what I said at all, you'll throw a bunch of codes if you remove them You'll have to tune out things with a programmer to stop all the wailing from the computer. It's a waste of time and money.
Old Nov 23, 2009 | 12:58 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
spend the money and buy a set of long tube headers with or with out high flow cats then get it tuned.
Old Nov 23, 2009 | 01:15 PM
DevilMan02's Avatar
DevilMan02
If you want cheap sound, search for Borla Straight Pipe catback and their xpipe. I love mine and they're cheaper than the SLP loud mouths.
Some people who've had them say they're too loud but I wish my car was actually louder. Its a sad day when a Nissan 350z can rev louder than a Vette. I'm told it will be a but louder when I get headers and delete the cats.
FYI, you're also about to be lectured by people trying to save polar bears and the environment.
Old Nov 23, 2009 | 02:16 PM
dougbfresh's Avatar
dougbfresh
Removing cats for a regular street car is almost a waste and by the time you have the codes tuned out and spent the money to bypass them, you could have bought a legal mod to get the same power. If you just want noise, get some of those electric cutout, you should be able to cause some coal mine cave-ins there in the hills of WV with the noise you'll make. Silent but deadly is much better anyway.
Old Nov 23, 2009 | 02:26 PM
Indy's Avatar
Indy
I believe that you can actually get some O2 simulators when deleting the cats...the sound without cats will be great...too bad that they have such strict emission tests here in Vancouver...Indy
Old Nov 23, 2009 | 10:52 PM
DevilMan02's Avatar
DevilMan02
PS - the straight pipes alone are enough to trigger car alarms in the parking garage at work.
Old Nov 23, 2009 | 11:26 PM
HowlinC5's Avatar
HowlinC5
Just get oygen sensor simulators.
Old Nov 24, 2009 | 08:30 AM
markcvechko
Default WV Coal Mine
I have worked in the coal mines and have loss friends in mine explosions and it was not because of loud pipes. If you want to be a smart azz then just keep your mouth shut. Mark A. Cvechko West Virginia
Old Nov 24, 2009 | 08:35 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
If you are going to drive the car on the street then do not remove the cats. The almost undetectible increase in HP is not worth all the problems of running no cats.
Also, it is against federal law to remove the cats.
Old Nov 24, 2009 | 09:39 AM
markcvechko
I drive the harley more and it has no cats. I know what the federal law is. My question was would it throw codes, which has been answered and what would the sound change be in the exhaust, which has not been answered.
Old Nov 24, 2009 | 10:08 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
BTW, independent1 is my brother and works for the EPA.
Unless you're using the car for off-road purposes, there is no reason to remove the cats. You and your car will stink to high heaven.
The smell both inside and outside the car is obnoxious. You don't even need to look to see that the car doesn't have cats, you can smell it.
Also you will have to replace the cats before selling the car or you could get a serious fine and even thrown in jail for a few years.
Furthermore, O2 similators are illegal and you would be hard pressed to find them for sale anywhere as the EPA has gone after all of the manufacturers of these items.
Old Nov 24, 2009 | 10:53 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
It will be "Fuller" sounding and maybe 10-15 % louder Mark.
I agree with the above, long tubes with an "off road" section, instead of the HF cat section...
By the way, you can get the HF cat section from Random Tech, but it is half the price of long tubes...
Peace
Chip
__________________
..................Click for
Unless there is a problem with your current cats, I'd see no reason to take them off. You won't gain much in the way of performance. If you want a louder exhaust, just get an aftermarket catback system.
Old Nov 24, 2009 | 10:55 AM
CCA Corvette Parts
He has Pace Car's...
Peace
Chip
To Cat removal
Old Nov 24, 2009 | 01:27 PM
markcvechko
Peace
Chip
I do not know how asking a simple question can lead to so many BullSht answers. Chip I tahnk you for the correct answer. Mark
Old Nov 24, 2009 | 01:32 PM
markcvechko
Default Epa
I do not give a rats azz if your brother is with the EPA or CIA. If you and him both want to come to West Virginia and go face to face I will be happy to ablige you. Otherwise as Barney would say Nip it in the bud. Thanks for all the useless information and go back to hunching a tree. This is Mountaineer Country. Mark A. Cvechko
Old Nov 25, 2009 | 09:27 AM
Independent1
St. Jude Donor '08
^^My brother's comments were not said as a challenge. A lot of the advice on this forum, although maybe well-meaning, is just plain wrong.
You would do well to listen to the people telling you that running without cats on the street is not a good idea. However, the final decision is yours.
FWIW, you come across as a flaming azzh0le.
