Vortex Generators
Old Nov 23, 2009 | 09:01 PM
supersupereight's Avatar
supersupereight
Default Vortex Generators
Ive read alot on the sight ECOMODDER..
Other Cf members should check it out..
There have been some extensive real world testing by members there and confirmation that they do work..
Any opinions?? Any real world experience?
Obviously one factory team..Mitsu believes they work and has published a 3 page report about the beneifits...I just read it!
Just wondering what the CF members have to say..?
Old Nov 23, 2009 | 09:20 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Mitsubishi
Old Nov 23, 2009 | 09:25 PM
Choreo's Avatar
Choreo
I was wondering why it was taking me so long to get to the post office every day!
Old Nov 23, 2009 | 10:17 PM
itzza427's Avatar
itzza427
I've seen a C5 with them,,,and they are kinda UGLY!!! Not to mention they are a little bizarre looking as well !!
Old Nov 24, 2009 | 07:11 AM
AU N EGL's Avatar
AU N EGL
They are not 'vortex' generators they are spoilers to produce slight down force.
C6R
DBR9
Old Nov 24, 2009 | 08:46 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
A vortex generator is a series of small vertical fins or vanes designed to create vorticies to keep airflow streamlined over the trailing edge of a given surface at speed. Most aircraft have these on the leading edge of the wing to give a lower stall speed. for a car to have the same effect, you'd need to mount them somewhere forward on the roof. This would be most effective on FRC cars where the rear window drop-off angle is significantly steeper than the targa coupes.
the only catch is that by making airflow "adhere" to the body you also turn the car into an airfoil and at speed, this creates an area of low pressure over the rear wheels and lift This is why many supercars have spoilers, wings, and air diffusers to creating downforce counteracting the "lift" of having a smooth airfoil lines.
Old Nov 25, 2009 | 11:51 AM
supersupereight
My carbon fiber wing is set to arrive next Tuesday...
I plan on using the vortex gen and the wing as a package
I was informed that I should place the vortex Gen 4" behind the peak point on the roof to achieve optimal results.
That would put them on top back edge of the halo..
Any opinons on placement to optimize performance
Any opinions on best angle to set wing at..
Old Nov 25, 2009 | 12:34 PM
AU N EGL's Avatar
AU N EGL
the Corvette does not need a roof spoiler for aerodynamics.
just the small 1" rear deck spoiler at 45* AoA. and proper alignment and good to go.
now if you are talking about a REAL WING, bolted to the frame, not the rear deck, then a 2" front splitter and extractor hood are needed for down force.
The wing AoA would be determined by how large wing and the Gurney lip is or if you have one at all ?
then weather you are on a (1) low down force high speed straights,(2) high down force high speed cornering (3) intermediate down force and speeds.
if the wing is just bolted to the deck lid and not the frame just put it level. any AoA may crush the deck lid.
Old Nov 25, 2009 | 12:46 PM
Navyvette04's Avatar
Navyvette04
I could not have said it better myself.
Old Nov 25, 2009 | 01:16 PM
96solo's Avatar
96solo
You're right in my opinion, but there was NASCAR studies shown online that indicated that the rear spoiler lip should be 53 degrees for the best downforce. APR indicates that a wing should be set for 12.5 degrees in the middle section for a FRC and less for regular Corvette rear deck.
J.R., sponsored by Pfadt, has a Vortex Gen on his Corvette roof (#240) that he's selling. you should ask him about the effectiveness.
To Vortex Generators
