How do you not scrape?
Old Dec 2, 2009 | 01:45 PM
  #41
SFL_driver's Avatar
SFL_driver
Angle angle angle Some times you just have to suck it up and hope it's just the black plastic
Old Dec 2, 2009 | 01:49 PM
  #42
REDEVIL's Avatar
REDEVIL
...and when I say "scrape" I mean the center section of the car contacting the ground/speed bump...not the front air dam. Believe me, it is not a pleasant noise to hear.
Old Dec 2, 2009 | 02:05 PM
  #43
hunterman's Avatar
hunterman
I just try the best angle I can and hope to scrape as little as possible. I cant imagine it being lowered and scraping even more.
Old Dec 2, 2009 | 02:13 PM
  #44
Dominic Toretto's Avatar
Dominic Toretto
Drive the car cautiously before lowering and continue driving cautiously afterwards. Simple.
-Alex
Old Dec 2, 2009 | 02:40 PM
  #45
rboineau's Avatar
rboineau
Default Scraping
Anyone who lowers one of these already-too-low cars is a moron.
Old Dec 2, 2009 | 02:46 PM
  #46
Superman09's Avatar
0Superman09
Former Vendor
cool glad you enjoy stating your useless opinions! Next time you post, maybe you could try to be beneficial to the poster
Old Dec 2, 2009 | 02:53 PM
  #47
blackmachdown's Avatar
blackmachdown
Yeah ok, go look at the roadracing forum and post that there I double dare ya
Old Dec 2, 2009 | 03:01 PM
  #48
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by Superman09
Yep. Lower it, get some fattdaddy rollers, and trim your air dam up and it's not so bad...
FattDaddy's are BO for about a month...
but
FattMammas and Rocker Panel Skid Plates are instock and shipping daily...
http://www.customcorvetteaccessories...fattmamma.html
Peace
Chip
__________________
..................Click for
Old Dec 2, 2009 | 03:05 PM
  #49
dougbfresh's Avatar
dougbfresh
No speed bumps or potholes on the track! It is a silly idea for the street unless you "bag" it.
Old Dec 2, 2009 | 03:12 PM
  #50
blackmachdown
Lowering a car isn't a all or nothing ordeal mine is lowered and I can drive fine on any street and go up most driveways. Just because it doesn't follow YOUR IDEAS OR PREFERENCES doesn't mean it's dumb or retarded or a bad idea.
Old Dec 2, 2009 | 03:21 PM
  #51
Dominic Toretto
-Alex
Old Dec 2, 2009 | 03:34 PM
  #52
gradykd's Avatar
gradykd
Not to get off the subject, but how much is the average labor cost for lowering a vette on stock bolts?
Old Dec 2, 2009 | 04:11 PM
  #53
superstreet's Avatar
superstreet
St. Jude Donor '10
Yep. Lower it, get some fattdaddy rollers, and trim your air dam up and it's not so bad!
I'm assuming you mainly scrape your air dam which isn't anything to worry about, hell it was designed so it could take that made out of flimsy rubber/plastic and on hinges in the center. Save your lower radiator frame with the rollers and trim ~1" off the air dam and you'll be fine. 1" off my air dam has ZERO cooling effects and sits just a hair over the rollers so therefore the air dam NEVER scrapes. If I ever hit anything it is the rollers on steep inclines/declines however I am lowered nearly 3" on coilovers.
Hope this helps!
Old Dec 2, 2009 | 04:21 PM
  #54
REDEVIL's Avatar
REDEVIL
Hope this helps!
How do you avoid bottoming out on speed bumps? This is my biggest problem.
Old Dec 2, 2009 | 04:41 PM
  #55
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
This just hasn't been my day. I'm a moron for not driving in the rain and now I'm one for lowering my car.
Old Dec 2, 2009 | 04:56 PM
  #56
dougbfresh's Avatar
dougbfresh
You really can't. There are some streets around here where the speed bumps are completely across both lanes and 10" high.
Old Dec 2, 2009 | 05:04 PM
  #57
Dominic Toretto
My car is lowered all the way on factory hardware and it still scrapes the same as it did stock. It's not a life-changing event as some are exaggerating it to be. I would only be concerned with a full on race drop with coilovers. Common sense > this thread.
-Alex
To How do you not scrape?
Old Dec 2, 2009 | 05:09 PM
  #58
Superman09's Avatar
0Superman09
Former Vendor
honestly have never been over one, avoid them at all costs
Old Dec 2, 2009 | 05:16 PM
  #59
REDEVIL's Avatar
REDEVIL
Atta boy. I usually do as well, but my new work facility has three big bastards as soon as you drive into the parking structure! Hence, I've only driven it here 1 time.
Old Dec 2, 2009 | 05:25 PM
  #60
dougbfresh's Avatar
dougbfresh
Usually happens on an unfamiliar street in the dark.
