1ST corvette need advice
Old Dec 6, 2009 | 01:57 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Originally Posted by New Jersey
make sure to drive it as often as possible
contrary to popular belief, it is a car
That's what my AWD TrailBlazer SS is for.
Old Dec 6, 2009 | 02:02 PM
buzz12's Avatar
buzz12
Originally Posted by RubenTrinidadz06
this is my first year with a vet, i'll be storing it in an un heated garage. If I start it every week to two weeks, should i keep the battery on a slow trickle, gas stabilizer, etc. I live in chicago.
I moved from Ohio to Arizona !
Old Dec 6, 2009 | 05:12 PM
DevilMan02's Avatar
DevilMan02
I had no choice one year but to leave my car covered and parked outside in the dead of winter in New England. I just started the car twice during the periods where the snow had melted enough for me to lift the car cover and open the door. It ran just fine.
It's a car. Not an oil painting...
Old Dec 6, 2009 | 05:45 PM
seamus2154's Avatar
seamus2154
Originally Posted by dougbfresh
I keep mine on the tender and start it every couple of weeks to let the oil circulate. If it's dry outside I even run it around a little.
You not listening. Don't start it unless your going to drive it for a good period of time. The oil does not need to circulate till your ready to use it. When you start it it takes a while after reaching operating tempature
to burn off any water/ condensation. Circulating bad oil w/ water in it is bad for your motor and you are just mixing it in and running the motor w/ it. That's why short trip cars should change their oil more often because it isn';t running long enough to burn off the water. Your oil has to reach over 200 degrees for that to even start.
Old Dec 6, 2009 | 06:32 PM
El Paso Vette's Avatar
El Paso Vette
Wow, I had no idea that you had to do all that to keep a car over the winter. We don't get any snow or cold weather so we drive them all the time but you guys have really thought out how to store the car over the winter.
Old Dec 6, 2009 | 07:10 PM
Phanni's Avatar
Phanni
Actually, starting the car once amonth and running it for just a few minutes is a good idea. Today's gas often has ethanol in it and when it sits in your injectors for long periods, it is known to gum up the system. A simple start and short run clears out the gas and keeps the varnish from forming. Ask any mechanic that knows folks that store their cars for long periods.
Old Dec 6, 2009 | 07:14 PM
Phanni's Avatar
Phanni
Here's a linkhttp://www.hagerty.com/NewsManager/t...1123&zoneid=72
Old Dec 6, 2009 | 07:18 PM
j0n's Avatar
j0n
Originally Posted by supersupereight
Summer tires or anytire not designate as an allseason tire will freeze up at 32 degrees and loose there grip and elasticity and are worthless.
They will not hold the road and your just asking to have an accident.
I just took my car for a ride 30min ago in 28* weather and beat the snot out of it. Amazingly, I didn't crash. I also took several on and off ramps at 50+ without a hitch.
Old Dec 6, 2009 | 07:29 PM
hatewhatownsyou's Avatar
hatewhatownsyou
2nd gear, foot to the floor doing 55mph my wheels will start spinning
KDW's dont like the cold
Old Dec 7, 2009 | 07:14 AM
j0n's Avatar
j0n
Nitto 555 FTMFW
Old Dec 7, 2009 | 01:23 PM
seamus2154's Avatar
seamus2154
Yes, while that is an issue there are too many down sides to starting the car for a few minutes, especially in cold weather. 75% of engine wear is at cold start up plus the oil and water issue. To combat that issue a gas stabilizer is the answer. Stabil. There are many things to do for storage and alot has been said here about it, but starting it is not one of them.
