2008 rims
Old Dec 3, 2009 | 09:13 AM
jmc17's Avatar
jmc17
Cruising
Default 2008 rims
Looking to see if a set of 2008 rims will fit on a 1998. They are 18x8.5 and rear 19x10. Thanks for any input.
Old Dec 3, 2009 | 09:18 AM
jrose7004's Avatar
jrose7004
This question is ask and answered everyday on this forum. Search can be your friend here.
Old Dec 3, 2009 | 11:35 PM
atmsrus1's Avatar
atmsrus1
I have a set repros on my 01
Old Dec 4, 2009 | 01:32 PM
jmc17's Avatar
jmc17
Cruising
Thank you for answering, much appreciated.
Old Dec 4, 2009 | 01:45 PM
New Jersey's Avatar
New Jersey
you need a 1" spacer for the rear to look right.
Old Dec 4, 2009 | 02:05 PM
terrywerst's Avatar
terrywerst
I agree with above. They fit and lok great, but you need that spacer in the rear. They look to pushed in without this.
Old Dec 4, 2009 | 02:49 PM
TooMch's Avatar
TooMch
...in other words the lug patterns are the same but the offset (how far the wheel sticks out or tucks in) is different between the C5 and the C6. The spacer takes care of that difference.
Old Dec 4, 2009 | 04:24 PM
my6thvette's Avatar
my6thvette
This is an OEM C5 rear wheel on a 1999 C5.
This is an OEM C6 rear wheel, without a spacer, on the same car.
I really don't see that there is much difference in how they look in the wheel well. However, some cars may require a 1/4 inch spacer to prevent the rear tire from rubbing the wheel well.
Old Dec 7, 2009 | 01:36 PM
TooMch's Avatar
TooMch
hmmmm.... interesting. Good comparison shots. I thought they had to be C6 repros to look that close.
Old Dec 7, 2009 | 01:48 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Here's my C5 with the wheels off my 08 on it. I did use a 1/4" spacer on the rear to keep the tires from rubbing the inner fender on hard cornering.
To 2008 rims
