Front Spoiler, Right Side
Old Dec 10, 2009 | 04:24 PM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
Originally Posted by dlivewyer
I believe that the center portion acts as an air dam and forces air up to the radiator. Without it you may not get enough air through the radiator.
You need it...
Old Dec 10, 2009 | 07:54 PM
BOTTOMS UP's Avatar
BOTTOMS UP
Originally Posted by killain
I went through this same thing last summer. The side pieces are held on with a #6 sheet metal screw with a washer head, and it's a 6MM socket to remove the original air dam. I'd get Gene Culley to sent you to new one, (I have a extra set because GM is more than likely going to discontinue the production if nor already) The c-clip that holds it up is a (Machine screw) clip but it was never corected. I wrote to Corvette/Enthusiast magazine and I submitted it to their tach folks and It is published in this months issue, Feb 2010. But what i found out as to the side air damn is that over time the corner sags. I even went so far as to have two alumium side surpports fashioned and was going to install them what i found out that the parts A small C-clip and the corresponding bolt/screw where totally different acourding to the current GM parts cataloge so i assume this problem is a small issue as wa over-looked by the engineers?
Now having said that, Chris Petris wrote back and upon seeeing my problem with two totally different fasteners, looked up the 'Correct' part numbers. I was using part# 19310412 & 19310413 which are the correct # as Right and left air dams. But he provided the fasteners as #11515638 & 11515757. This is i believe is the correct part numbers But I have yet to try to install them. And as far as getting a air dam support part, forget it. Their made out of cheap plastic, and couldn't how up a sheet of printing paper from your computer printer.
should be a 7mm
