How to remove louvers?
Old Dec 7, 2009 | 12:10 AM
mfastert's Avatar
mfastert
Default How to remove louvers?
They came with the car and I'd like to remove them. I tried popping the rivots off from the outside but that didn't work. Do I have to go throught the trunk and access panels? I didn't put them on so I have no idea how to remove them. Thanks as always for the help.
Old Dec 7, 2009 | 12:12 AM
ALLEGRO's Avatar
ALLEGRO
Not sure what you are referring to. Louvers on the lights, plate......not sure?
Old Dec 7, 2009 | 02:08 AM
dobewillie's Avatar
dobewillie
Old Dec 7, 2009 | 02:34 AM
richard emmanuel's Avatar
richard emmanuel
Originally Posted by dobewillie
post a pic please or take it to a local body shop. Is there a manufactures name printed some where...hummmmmm
Old Dec 7, 2009 | 04:07 AM
steve8's Avatar
steve8
Don't know, but you're doing the right thing by taking them off.
Old Dec 7, 2009 | 04:48 AM
DeeGee's Avatar
DeeGee
I've never seen the fit but cant you just unscrew the normal screws that hold the light unit in place. That would let you see how they're fitted
Old Dec 7, 2009 | 08:17 AM
mfastert's Avatar
mfastert
They are tail light louvers. Is there an outside screw that holds the tail light in? If so, the louvers are covering them and I can't seem to pop off the rivot. There is not a manufacturer listed on them.
Old Dec 7, 2009 | 09:30 AM
jrose7004's Avatar
jrose7004
Unscrew them, take them off and get the right sized screws for your taillight lense.
Old Dec 7, 2009 | 09:43 AM
Bill Vett's Avatar
Bill Vett
Plastic caps covering the screw heads? There has to be screws holding them on.
Old Dec 7, 2009 | 09:47 AM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Louvers normally attach using the same screws that hold the tail light lenses on. One screw at 3 o'clock and one at 9 o'clock. Should be able to remove the two screws, take the louvers off and rescrew the lense back on.
Nick
Old Dec 7, 2009 | 10:11 AM
bucwheat's Avatar
bucwheat
That sounds about right,can't see the screws for the caps.
Old Dec 7, 2009 | 10:12 AM
mfastert's Avatar
mfastert
If it was that easy I would have done it. I know the tail lights screw in but there is not a screw exposed. I thought there was just a plastic cap covering the screw but when I tried to pry it off I messed up the louvers. I will take another look at when I get home.
Old Dec 7, 2009 | 11:37 AM
Bill Vett's Avatar
Bill Vett
Try removing the license plate surround and reaching up to the tail lights to see if you can feel threads on the fastener. I could see rivets if the person has stripped the threads on the install of the louvers. Keep us posted. Bill
Old Dec 8, 2009 | 11:08 AM
I'd bet there is a plastic cap covering the screws - the lights mount with screws from the factory and I know of no other method to keep them in place than that.
Old Dec 8, 2009 | 11:12 AM
mfastert's Avatar
mfastert
I won't get a chance to look at it till Thursday. I have my car stored at my parents house for the winter. I'll keep you updated.
Old Apr 19, 2010 | 03:01 PM
mfastert's Avatar
mfastert
There was a plastic cap over the screws and it was impossible to remove. I ended up taking a knife and cutting two deep slots into the cap and then used a screwdriver to remove the screw, through the cap. Once the screw is off, the cap can then be removed. This destroys the cap but not the louvers.
To How to remove louvers?
