Looking for the rear marker lights that are flush and have the corvette logo on them. Any help would be greatly appreciated
gscreationsllc.com ( http://www.gscreationsllc.com/produc...roducts_id/112 )... that's where I got mine. but be warned... they are not just bolt up replacements. They consist of a flat piece of lexan that has been etched with the logo and get taped to the outside of the car. Then there is a lexan piece that holds the LED that gets taped to the inner fender and shines through the hole in the body... and that hole in the body will have to be trimmed so the tips of the flags are lit up.
Thanks Jedi!!!! What would rate the quality of the light?
It seems a little dim... especially if it's not completely dark outside. I was thinking about getting some brigher LED's to see if that helps but have not done that yet.
Also, if looking at it from an angle, it doesn't appear to light up the whole emblem because of the angle that the light is coming through the hole in the back (as well as there is no diffuser for the light). Other than that... I love the look.
cluster 194 led's might work for you , they seem to be brighter than stock bulbs. I think mine are 9 led's. Bill
Do they come in red? The LED's would have to be red since the Lexan is not tinted red. Also, it would be very important that the majority of the light go out from the end like a flashlight since it is shining through a hole.
Yes they are clear and light up red . I used them in my clear side marker lights and they're bright. check here...http://autolumination.com/194.htm194 Signal/Marker Bulbs.
With the cover being held on with tape, how well does it fit? Did you do the Dremel part of the install? Does the Dremel part of the install affect going back to the stock lights? Overall, are you happy with this product. I'm considering a QS cover for my Z06.
Yea... I did the Dremel part. I was VERY nervous about cutting into the body, but I was careful an only cut what was needed. It shouldn't affect the ability to go back stock. You don't cut into the holes where the stock mounts, only make the hole where the bulb goes through a little bigger.
Overall I am happy with the product... I just wish that the LED was brighter and that you could see a more uniform glow from any angle, but I don't see how that could be accomplished and still stay so flat to the body without really cutting into the body a lot.
Who makes those and do they have them with a Jake skull? I mean the damn car has enough vette flags on it we know it's a corvette the flag is overdone already.
I wish they would have had Jake skulls when I bought mine. That would be AWESOME and might not require you to dremel out the body.
