PCM code help
Old Dec 11, 2009 | 06:48 PM
paullywalnuts's Avatar
paullywalnuts
Default PCM code help
Ok..need a little help...got a "C" code "10 PCM 1 code" in the DTC;(P0430 H C)...I've learned that it's Powertrain Control Module and it's meaning is {System Low Efficiency Bank 2-A}....Check Engine Light is on obviously which prompted all of this, however, I have not noticed anything wrong or different about the car (2000 Non-Z with 39K).
All the other codes (there were several under different modules) but they were all H...the above listed code was the only one with a "C" after it which I understand to be "current". I reset all codes to show "no codes"..but the check engine light came back on after about 10 minutes of driving.
Could this be Cat related...exhaust has been a little smelly lately..have had Melrose headers on for a few months...Corvette Dr. said I may get a code at some point...he said he didnt need to tune it after install since they're Melrose and not LG's.
I read this site: http://www.gearchatter.com/viewpost14093.php but it doesn't really help me determine if something is wrong..will it go away after so many ignition cycles?
..any ideas would be greatly appreciated....thanks..Paully.
Old Dec 11, 2009 | 09:53 PM
ragtopws6's Avatar
ragtopws6
First, you might get better response if you post this on tech section.
The P0430 means the bank 2 cat is ineffient. If you don't find any leaks, replace the cat converter.
Old Dec 11, 2009 | 09:57 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Did you recently get headers or anything??
Anyway, Thats a common code for headers and hi flow cats. ( the one i got, i got the rear O2s deleted, no more cel.)
Old Dec 13, 2009 | 07:28 AM
paullywalnuts
Yea I reset it again and it's been gone for a day. It's gotta be related to the new cats/headers I got 4 months ago...I just didnt think it would take this long to throw a code...thnx.
Old Dec 13, 2009 | 10:34 AM
ragtopws6's Avatar
ragtopws6
You can either delete the code from your PCM or use O2 simulators.
Old Dec 13, 2009 | 01:52 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yup! Mine took a few months for the code to come as well. Sometimes it will stay away for a day or so, etc...
To PCM code help
