Upgrading your C5 rear with C6 Z06 guts
#101
From what I found the C6 Z06 washers are stronger, but not as strong as the DTE ones, which are also designed to work with their carbon clutch pack kits. I already had the c6Z06 clutches so I kept the washers.
Even with 19k miles I will bet you at least one of your washers is cracked. Here is mine at 25k, owned since 16k miles. If you are in the area of having the diff opened up, I would replace the washers.
http://forums.corvetteforum.com/1584533996-post49.html
#103
I just picked up a 3 rib diff with 2.73 gears for almost nothing. The carrier is all I need to change over from my current diff (besides reshimming) to put 3.42s in the 3 rib, correct? I thought all the cases were the same, just the carriers in them were different.
The diff will be getting C6 Z06 internals and possibly 300m shafts.
#104
I don't have good reference pictures on this computer, so i'll use ebay.. Take a look at the location of the sensor body with reference to the rib in the case..
3-series carrier case:
http://www.ebay.com/itm/C5-Corvette-2002-Z06-3-rib-3-42-Rear-Differential-44K-/261298008276?pt=Motors_Manuals_Literature&hash=item3cd69330d4&vxp=mtr
2-series carrier case:
http://www.ebay.com/itm/C5-Transmission-and-Rear-Differential-/121180580912?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c36ecec30&vxp=mtr
#110
sorry to dig this up , but u guys might have the answer..
will the zr1 out put shafts fit in the c6 z06 carrier..
i plan on doing this whole c6 into the c5 thing here in the next few weeks
and what about the zr1 carrier itself? is that any stronger..
#112
#114
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
The 3 series and the 2 series have different cases. You can install the 3 series carrier into a 2 series case but the speed sensor will NOT line up correctly (your speedometer will not work).
#116
Looks like i have a paper weight being shipped to the house..... Oh well, I guess it goes out to the curb the next time the city has brush and rubish pick up.....
#120
Supporting Vendor
There were 3 differentials that came in C5 (1997-2004). 2.73, 3.15 and 3.42's. Yes, any Z06 diff is a good candidate for C6 Z06 guts.
