winking vette
Old Dec 12, 2009 | 09:47 PM
tom01ss's Avatar
0tom01ss
Former Vendor
Default winking vette
i know its stupid but comeon made me rofl
http://www.youtube.com/watch?v=Ierse...eature=related
Old Dec 12, 2009 | 10:16 PM
moserbe's Avatar
moserbe
Old Dec 12, 2009 | 10:25 PM
dlivewyer's Avatar
dlivewyer
Old Dec 13, 2009 | 12:35 AM
jrose7004's Avatar
jrose7004
That's a scream!
Old Dec 13, 2009 | 01:34 AM
damilleniumboy's Avatar
damilleniumboy
Old Dec 13, 2009 | 02:21 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
That is funny! Have you fixed it yet?
Old Dec 13, 2009 | 02:22 AM
DeeGee's Avatar
DeeGee
Funny
I guess he's not a CF Member or he'd know how to fix it
Old Dec 13, 2009 | 03:07 AM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Thas pretty funny. First time I have ever seen that
Old Dec 13, 2009 | 06:45 AM
DAV162's Avatar
DAV162
Old Dec 13, 2009 | 06:55 AM
dquagliaroli's Avatar
dquagliaroli
wait until it gets dark and they won't open at all.
Old Dec 13, 2009 | 09:03 PM
tom01ss's Avatar
0tom01ss
Former Vendor
lol made me laugh no its not my car stumbled on it one nite had to post it
Old Dec 13, 2009 | 09:37 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Old Dec 14, 2009 | 03:06 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Old Dec 14, 2009 | 04:16 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I thought it was funny too. You can hear me laugh at the end of the video.
I video taped that. That car belongs to a former CF member who was perma-banned for some foolishness. I posted about it a while back. Click here for the original thread.
He posted a good fix for it there. Here it is in case anyone needs it.
Originally Posted by MikeC4
To Larry....... thanks again for posting a vid of my "winky".
To TheRadioFlyer.....Thanks for the disassembly procedure. I especially like the fact that I didn't have to remove the entire driver side Headlamp assembly to fix the 2 problems that where lurking beneath.
1) The plastic cover that is GLUED on over the nylon gear had popped off. This was a huge GM blunder when they changed from cast aluminum cover('97 to '99 models), which uses 3 screws to secure the cover, to a completely plastic housing for the motor/worm gear and nylon gear(2000 to 2004). The nylon gear will push against the cover, and it is only a matter of time before the pressure breaks the GLUE bond......and I don't care what kind of magic glue there is out there, it will not hold.
2) As per GM service bulletin, motor should be offset with washers so that the armature which raises and lowers the light makes better contact with the limiter tabs. There were enough customer complaints regarding faulty operation of the driver side Headlamp to issue this bulletin, and how to correct the problem.
I took some pics and added notes on what I did to fix both of the above design flaws, as well as how to eliminate the need for GLUE for the motor housing cover.
Job Completed. Took me about 2 hours, but I move real slooooooooooooooooooow.........otherwise I get more "honey do's" when I go into the house !!! (-; Another benefit was that I could better align the body colored headlamp cover, as the folks at GM did a poor job on this as well. This adjustment is done by maneauvering the cover directly under the body panel to adjust/equalize the top/bottom/left/right gap clearance .
The following pic is out of sequence, but I did want to show the 2 critical pivot bolts that hold the light assembly to the..........car
Below are the only tools required for this job:
Take a look at the following picture. This is what you will never have to mess with again!!The "wrap tie" method will eliminate the need for GLUE, can be done without removal from car, and will surely last a very long time !! But if you like the GLUE method, here's a pic I found in the DIY section....
To winking vette
