thanks for the pics that will make it way easier cant wait to get them on I've had them for about 6 months now, but have been deployed overseas 5 months of that.
Thanks and yes it was, I have been in for 18 years and spent the last 5 of 8 years over seas 10 times to Iraq and a few times to some other unsavory places.
Yep, you need to drop the sway bar and small, passenger-side gas tank shield on an A4 to get the proper clearance. Only need to drop the sway bar on a manual.
Patches,,,you have to be one of the FEW people in the world that could work all day under your car,,,and not get dirty!! That undercarriage is AMAZING!! Don't know which I would be shorter of,,,TIME OR PATIENTS to get it that CLEAN!!!
Yes - in fact, I often get the undercarriage dirtier just by touching it without gloves. Actually, Carole's car gets dirty due to the dd role it plays but I always take the opportunity to clean it up whenever I get it on the lift for mods or maintenance.
All you have to do is loosen the bolts holding the sway bar in place and swing it down - then you can unbolt the exhaust and install the Ti system. You just need to get the car up in the air high enough to swing the pipes over the rear axles.
