Exhaust Question
Old Dec 13, 2009 | 07:50 AM
zx12rfl's Avatar
zx12rfl
Default Exhaust Question
I have a question about installing a TI system on my car, the guy I called about doing it tells me he needs to lower the transmission and the suspension, is this the case? I really dont want someone dropping my suspension and transmission if this does not have to be done?
Old Dec 13, 2009 | 07:55 AM
RSchleder's Avatar
RSchleder
Doesn't sound right to me. I took my exhaust off my 2000 vert without any of that. You do need to get the rear end up in the air to do it though!
Old Dec 13, 2009 | 08:01 AM
zx12rfl's Avatar
zx12rfl
thanks I will just put it up on a hoist and do it myself, I thought I would take it to someone and have them do it as I thought it would be quicker.
Thanks again
Old Dec 13, 2009 | 08:55 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The guy is full of "CRAP" you will want to drop the sway bar - it simply swings down out of they way and it aids in the install!
You "ONLY" have to un-bolt the to Brackets/holders for the bushings and not the endlinks
You will need to get the rear end up pretty high so use jack stand and a good jack and you will need blocks of wood!
Thanks,Matt
Old Dec 13, 2009 | 09:09 AM
arkus's Avatar
arkus
Thanks,Matt
Cybermind's Avatar
Cybermind
That's probably because he doesn't have a lift or way of lifting the rear end high enough to get the over-axle pipes on. I wouldn't have anyone touch my transmission and/or axle just to install a catback exhaust. That's crazy.
Old Dec 13, 2009 | 09:12 AM
zx12rfl's Avatar
zx12rfl
Thanks Fellas appreciate all the information, I have access to a lift so I will take it to my buddies house and put it on the lift and do the above and put the exhaust in myself. Much appreciated all.
Old Dec 13, 2009 | 09:13 AM
Indy's Avatar
Indy
Don't let this guy come even within 100 miles of your Vette...He probably will unbolt the fuel tank to gas her up
Old Dec 13, 2009 | 09:17 AM
vette.mix's Avatar
vette.mix
Old Dec 13, 2009 | 09:33 AM
Patches's Avatar
Patches
Yep - he's clueless. Here's mine in progress on my lift at home.
Problem with doing it at home without a lift is you have to get the rear end at least 32" off the ground to achieve the clearance you need to get the stock exhaust out and the Ti's in.
Get an experienced, competent exhaust shop to do it for you.
Old Dec 13, 2009 | 09:37 AM
zx12rfl's Avatar
zx12rfl
dont worry I wont let him with in 15 miles of it...this is another reason I enjoy this forum, before I do things I ask here to make sure I dont screw my car up or let someone else screw it up. There is only one guy in the area who specializes in Corvettes he is up in Raleigh
Old Dec 13, 2009 | 09:40 AM
zx12rfl's Avatar
zx12rfl
dont worry I would never attempt to do this at home like that bottom picture.
Old Dec 13, 2009 | 10:18 AM
jrose7004's Avatar
jrose7004
Say away from that guy!
Old Dec 13, 2009 | 12:47 PM
03whitecoupe's Avatar
03whitecoupe
Damn Patches that's the cleanest undercarraige I've ever seen. It looks fantastic
Old Dec 13, 2009 | 12:50 PM
zx12rfl's Avatar
zx12rfl
he is off my list I will do it myself before I let him do it.
Old Dec 13, 2009 | 12:58 PM
Patches's Avatar
Patches
One of the benefits of a lift coupled with an OCD personality disorder.
Old Dec 13, 2009 | 05:08 PM
itzza427's Avatar
itzza427
If you put it on a lift as you say you can,,drop the sway bat supports,,you are looking at 30 to 45 minuets,,taking your time!! As others stated,,he is clueless. One hitch,,A4s are a bit more trouble than the M6s. Clearances are a bit tighter!!
To Exhaust Question
Old Dec 13, 2009 | 05:13 PM
MyOwn69's Avatar
MyOwn69
PATCHES!!!!!!!!
You forgot to block out your license plate!!
Now we know where to find you!
Great post, as usual!
Old Dec 13, 2009 | 05:28 PM
zx12rfl's Avatar
zx12rfl
Thanks all, I called a friend of mine who has 3 lifts at his house, we are going to put these suckers on next weekend, I will let you guys know how it went. have you guys seen a thread that shows how to fix the vacuum hose issues with the AC system?
Old Dec 13, 2009 | 05:31 PM
Patches's Avatar
Patches
Yep, you need to drop the sway bar and small, passenger-side gas tank shield on an A4 to get the proper clearance. Only need to drop the sway bar on a manual.
