Determining if Theftlock is activated
Old Dec 16, 2009 | 03:02 PM
Sailon's Avatar
Sailon
Default Determining if Theftlock is activated
I bought a used C5 and am not sure if the previous owner/dealer activated the Theftlock feature on the radio or not. How can one tell if this feature has been activated?
I want to disconnect the neg battery terminal for the winter but obviously need to assure that the theftlock feature isn't active.
Old Dec 16, 2009 | 03:17 PM
DeeGee's Avatar
DeeGee
Here ya go
THEFTLOCK is designed to discourage theft of your
radio. It works by using a secret code to disable all radio
functions whenever battery power is removed.
The THEFTLOCK feature for the radio may be used or
ignored. If ignored, the system plays normally and the
radio is not protected by the feature. If THEFTLOCK is
activated, your radio will not operate if stolen.
When THEFTLOCK is activated, the radio will display
LOC to indicate a locked condition anytime battery
power has been interrupted. If your battery loses power
for any reason, you must unlock the radio with the secret
code before it will operate.
Activating the Theft-Deterrent Feature
The instructions which follow explain how to enter
your secret code to activate the THEFTLOCK system.
It is recommended that you read through all nine steps
before starting the procedure.
If you allow more than 15 seconds to elapse between
any steps, the radio automatically reverts to time and
you must start the procedure over at Step 4.
1. Write down any three or four-digit number from
000 to 1999 and keep it in a safe place separate
from the vehicle.
2. Turn the ignition to ACC or ON.
3. Turn the radio off.
4. Press the 1 and 4 pushbuttons at the same time.
Hold them down until --- shows on the display.
Next you will use the secret code number which
you have written down.
5. Press MN and 000 will appear on the display.
6. Press MN again to make the last two digits agree
with your code.
7. Press HR to make the first one or two digits agree
with your code.
8. Press AM FM after you have confirmed that the
code matches the secret code you have written down.
The display will show REP to let you know that you
need to repeat Steps 5 through 7 to confirm your
secret code.
9. Press AM FM and this time the display will show
SEC to let you know that your radio is secure.
Unlocking the Theft-Deterrent Feature
After a Power Loss
Enter your secret code as follows; pause no more than
15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MN and 000 will appear on the display.
3. Press MN again to make the last two digits agree
with your code.
4. Press HR to make the first one or two digits agree
with your code.
5. Press AM FM after you have confirmed that the
The display will show SEC, indicating the radio is
now operable and secure.
If you enter the wrong code eight times, INOP will
appear on the display. You will have to wait an hour with
the ignition on before you can try again. When you try
again, you will only have three chances to enter the
correct code before INOP appears.
If you lose or forget your code, contact your dealer.
Disabling the Theft-Deterrent Feature
1. Turn the ignition to ACC or ON.
2. Turn the radio off.
3. Press the 1 and 4 pushbuttons at the same time.
Hold them down until SEC shows on the display.
4. Press MN and 000 will appear on the display.
5. Press MN again to make the last two digits agree
with your code.
6. Press HR to make the first one or two digits agree
with your code.
7. Press AM FM after you have confirmed that the
The display will show ---, indicating that the radio
is no longer secured.
If the code entered is incorrect, SEC will appear on the
display. The radio will remain secured until the correct
code is entered.
When battery power is removed and later applied to a
secured radio, the radio won’t turn on and LOC will
To unlock a secured radio, see “Unlocking the
Theft-Deterrent Feature After a Power Loss” earlier
in this section.
Old Dec 16, 2009 | 03:22 PM
87SAM's Avatar
87SAM
From the owners manual:
The instructions which follow explain how to enter your
secret code to activate the THEFTLOCK system. It is
000 to 1999 and keep it in a safe place separate from
the vehicle.
4. Press the 1 and 4 buttons together. Hold them down
until --- shows on the display. Next you will use the
secret code number which you have written down.
with your code.
with your code.
8. Press AM-FM after you have confirmed that the
secret code.
9. Press AM-FM and this time the display will show
The LED indicator by the volume control will begin
flashing when the ignition is turned off.
Unlocking the Theft-Deterrent Feature After a
Power Loss
with your code.
with your code.
5. Press AM-FM after you have confirmed that the
with the ignition on before you can try again. When you
try again, you will only have three chances to enter the
3. Press the 1 and 4 buttons together. Hold them down
with your code.
with your code.
7. Press AM-FM after you have confirmed that the
The display will show ---, indicating that the radio is
no longer secured.
code is entered.
in this section.
with your code.
with your code.
no longer secured.
code is entered.
in this section.
Old Dec 16, 2009 | 03:23 PM
87SAM's Avatar
87SAM
Old Dec 16, 2009 | 03:25 PM
8VETTE7's Avatar
8VETTE7
At about the 1 oclock position near the volume control of the radio is a small LED. It flashes with the ignition turned off if the Theftlock is enabled. Otherwise it is out.
Simple answer without reading the manual the previous responders sent...
Old Dec 16, 2009 | 03:34 PM
87SAM's Avatar
87SAM
Yes, that is pretty much a waste of time, nothing useful there!
Old Dec 16, 2009 | 04:35 PM
jrose7004's Avatar
jrose7004
There seems to be an echo in this thread!
Old Dec 16, 2009 | 04:43 PM
Sailon's Avatar
Sailon
PERFECT - I just checked the LED to the right of the Radio Volume control and it is not blinking so the previous owner never activated the theftlock. There weren't any codes in my owners manual so I was going to be in trouble if it was activated.
Thanks to all!!!
Old Dec 16, 2009 | 05:10 PM
vette.mix's Avatar
vette.mix
WOW go buy one off off of ebay for 75 bucks before going through all that
Old Dec 16, 2009 | 05:46 PM
GRUNIE's Avatar
GRUNIE
Who in their right mind would want to steal these radios in the first place?
To Determining if Theftlock is activated
