Scared To Death Now !
My 03Z06 has been a joy to own with very few issues...only had to replace the EBCM (under warranty) and I have put over 30,000 miles on it in the past two years. I also have few mods(see sig.)
Oh yeah, I did have to replace the stock LS6 Clutch because my new heads & cam added too much power
It's a nice problem to have...
I don't see where you listed the mileage. But you ought to change the trans and diff fluids. If they're original, follow the owner's manual.
Look under the firewall floorboard mat on the passenger side and see if the column lock bypass was installed. If not, DO THIS. It's the best $50you'll ever spend.
Since you probably don't know what you're looking for, take it to a Corvette shop--not a dealer, and ask them to look. It should take them 60 secs.
I've never been to this place, but Franks Performance Vettes in Costa Mesa is close to you. 949-646-5751.
And don't worry about water leaks in Huntington Beach. We don't get enough rain to worry.
Go to the Regional forum and look under So. Cal. You'll find a lot of events, cruises, etc. and you'll meet a lot of knowledgeable people who'll be glad to share experiences, advice, etc.
Enjoy the ride.
I just bought my first corvette only 13 days ago and love it. Since then I have scoured the classifieds for Chrome Wheels and aftermarket exhaust and have been excited to spend my nickles and dimes on my new (used) car.
I found what I was looking for and admire my beautiful 99 torch red Corvette every day.
But today I spent some time in the Tech Section of this forum and got VERY scared reading all of the inherent problems that guys are having with their c5's.
Everything from failing oil pressure gauges to water leaking into the car from poorly sealed body panels - and every other problem you could imagine.
MY GOSH ! did I buy something that is going to give me a life of misery if it is having problem after problem like you find in the tech section ?
I even saw many posts on guys having their oil pressure sending units go out on them several times in one month or more and they insist that they will continue to go out forever.
Just thought I would see if you guys are all doom and gloom here like seems to be in the Tech Section of this forum - I started getting depressed and shut my screen down after reading - NOT a happy place in that section - although it is a VERY HELPFUL place when you have a problem
I just hope I don't have a bunch of problems now - Kinda scared to start my car now to find out the Oil Pressure gauge is failed like all the others. Wondering also if my rear storage compartments are filled with water too.
I just want to shine it and drive it - not see it broke down in my garage.
Settle down..
Internet car forums predominantly discuss two major topics: Problems, and modifications. You can go to any car forum, and learn of common problems with that vehicle.....foreign and domestic.
If you go to the "Return Goods" section of a store after Christmas are you going to stop shopping there because everyone was returning merchandise?
Count up the number of C5 Corvettes made then count the posts for a particular problem. Calculate the percentage. It's not as bad as the Tech section would make you think.
Enjoy the ride.
To address your Questions - My new (used) Vette is a 99 and it has only 24,000 miles on it (Like New) - I'm the 3rd owner.
Under the GM VIS History Report it says -
N2061 - SWITCH - COLUMN RELEASE (STEERING) REPLACE 5542 MILES .
V0743 - ECL RELAY HARNESS REPLACE 5542 MILES
Is this the Steering Lock Bypass re-call you guys talk of ? Does this mean it has been done ?
The guy who sold it to me did not give me ANY maintenance records - The Oil Life Indicator on the dash says oil life 38 percent (Do I need to Change The oil yet ? - it is slightly brown but not bad - not black) I don'thave ramps or a low profile jack yet so I want to wait a few months till after the holidays -
Remember - ONLY 24,000 miles on it.
Thanks again guys.
Oh and FWIW, I'd say the same thing about ANY car that old with so few miles ... well with the exception of the diff seal.
Thanks again guys.
!!An aftermarket CLB,,is quiet!! If you want to ,,shoot me a PM.
Apparently, pretty normal turn of events. I did the same thing.Buy the car, start frequenting the forums, read about problems people have, run downstairs, check car....nope....back up stairs. Next day...read some more...gah! does mine do that?
....go check the car...nope.....well what if it "starts" doing that
Relax
its all good. These are great cars. They are near bulletproof. Even when you hear of a problem, its rare that it disables the vehicle. And as stated above, you can generaly either find out for yourself here whats going on and what needs to be done about it or in very short order someone will tell you whats going on even if you have no idea despite looking.Beats being at the mercy of whomever you bring it to if you have a problem. Always good to go into it with a little knowledge.
At any rate, we tend to skim over the "I love this car" info in posts and zero in on the "this weird thing happened the other day . . ."
Drive it, stare at it
and enjoy it, you're gonna love this car Look under the firewall floorboard mat on the passenger side and see if the column lock bypass was installed. If not, DO THIS. It's the best $50you'll ever spend.
