Scared To Death Now !
I just bought my first corvette only 13 days ago and love it. Since then I have scoured the classifieds for Chrome Wheels and aftermarket exhaust and have been excited to spend my nickles and dimes on my new (used) car.
I found what I was looking for and admire my beautiful 99 torch red Corvette every day.
But today I spent some time in the Tech Section of this forum and got VERY scared reading all of the inherent problems that guys are having with their c5's.
Everything from failing oil pressure gauges to water leaking into the car from poorly sealed body panels - and every other problem you could imagine.
MY GOSH ! did I buy something that is going to give me a life of misery if it is having problem after problem like you find in the tech section ?
I even saw many posts on guys having their oil pressure sending units go out on them several times in one month or more and they insist that they will continue to go out forever.
Just thought I would see if you guys are all doom and gloom here like seems to be in the Tech Section of this forum - I started getting depressed and shut my screen down after reading - NOT a happy place in that section - although it is a VERY HELPFUL place when you have a problem
I just hope I don't have a bunch of problems now - Kinda scared to start my car now to find out the Oil Pressure gauge is failed like all the others. Wondering also if my rear storage compartments are filled with water too.
I just want to shine it and drive it - not see it broke down in my garage.
Most of us have no real problems at all. I say enjoy and drive.
Historically the C5 is a very dependable car, the engine-life is above 200,000 miles, and the maintanence is minimal at best compared to imports. You are driving a well-built machine. Take care of it, service it and above all else: ENJOY it each time you DRIVE.
Good Luck
It ain't a Civic. So don't neglect it for years and years and expect it to keep chugging along. Preventative maintenance is key. And you can get a good heads up on potential future problems by trolling the forums.
And try to keep things in context. It's the oil pressure sender going out not the pump. The prior is an annoyance. The latter is a new engine.
Water leaks? Another annoyance, but my experience with sports cars is pretty much any car without a full window frame will leak at some point .. not if, when.
This forum is great in case you DO run into a problem, someone out there has probably already encountered it and can offer a solution.
So far, mine has been trouble free. (knock on wood)
Rob
If worried about sending unit just replace it.I dont know if i have ever seen a C5 on the side of the road. All in all every car has its problems,But I think a C5 a safe bet.The Best of Corvette for Corvette Enthusiasts
Have many miles of similes !
Now, I am afraid to leave my house for fear of being abducted by aliens.
If you are living on a very tight budget and can't/aren't willing to work on the car yourself, then I wouldn't buy a 10 year old car
The guys (and gals) on this forum are great - They put-up with my questions all the time
Forget about the oil pressure sensor - Cost of new one is about $25.00 and only takes 2 hours for a total beginner to repair
When you compare these against other manufacturers of cars in the Sport Car category (Porsche, Dodge, Jaguar, Lotus, ECT), you have the most dependable one
If you're scared of maintenance you should be glad you don't own a Ferrari!
With those cars, you put $1 in a jar for every mile you drive. It will be spent every 7.5k miles.
!! You'll see more pictures and stories of HAPPY owners
What happened is you seen maybe a 100 different Vettes with different problems on one page - Now tell which of those Vette's has all those problems at once and right now?
= NONE!If you get a problem or an issue on your Vette then you go to the page and ask a question or do a search and fix your 1 problem and then if you get another you do the same thing again - it's as easy as that
To say that everything you read is going to happen to your Vette is like saying you can put all the parts to a computer in a Home Clothes Washer and put it in cycle and when it is done you will have a complete working computer
Enjoy your Vette and do as much as you can for it - and the "BEST" thing you did for yourself is look at those pages so if an issue does come along you will remember - ohh I saw it there now I can fix it myself and not get raped by the dealer
I have a 1998 Coupe and have had almost NILL problems and when one came up (usually only one issue at a time) I fixed it - I have even done write-ups and How To's, just as many others have done - So Don't Worry be Happy! Ha-cunna Matada
Thanks,Matt (If you ever need to you can call my contact info is in the sig below
