Key FOB
Old Dec 18, 2009 | 12:24 PM
dlivewyer's Avatar
dlivewyer
Default Key FOB
My FOB stopped working. One day it worked, next day it didn't. I put in a new battery. Still no worky. Do I need to reprogram after a battery change?
When I shake it, it rattles. Sounds like a tiny piece of plastic inside it somewhere. I took it apart and found nothing. I shook the circuit board and that's where the rattle is.
Is it dead or what?
Old Dec 18, 2009 | 12:31 PM
65GGvert's Avatar
65GGvert
It's probably dead. I don't know if the 97 has a passive switch, but on the 98/99 the rattle is the passive feature activation device on the board. The best price for a new one is at www.gmpartshouse.com
From the web site above:
10253839 – 97-99 – 78.00
10432147 – 00 – 60.00
25695954 – 01-04 #1 – 65.00
25695955 – 01-04 #2 – 65.00
Old Dec 18, 2009 | 12:38 PM
dlivewyer's Avatar
dlivewyer
It does have the passive switch.
Old Dec 18, 2009 | 12:41 PM
65GGvert's Avatar
65GGvert
There's a little bell shaped device on the board. That's what you hear rattling. It is not an indication of a problem, but the not working is. Can you borrow a fob from someone for the 97 up to 2000 and program it to your car to test? I feel pretty sure you will need a fob. Around $78 from Gene Culley at the link I posted.
Old Dec 18, 2009 | 12:46 PM
dlivewyer's Avatar
dlivewyer
No access to other fobs. Do CF members get a discount? Price for a '97 shows $78.
Old Dec 18, 2009 | 01:00 PM
65GGvert's Avatar
65GGvert
You can use the 2000 for $60, it just won't have the passive feature.
Old Dec 18, 2009 | 01:09 PM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
Very easy to fix a non-funtioning fob, I just fixed the two fobs that came with my 97' last week. Neither were working after purchasing the car.
-Using rubbing alcohol and a q-tip clean the surfaces and contacts (it may look clean but can be very dirty)
- Using fine tip solder iron, solder the chip with 4 contacts on the top right corner (even if the contacts look fine they probably aren't, as in my case)
- Some other contacts may need it as well but you will only know after looking closely.
Here is a pic taken from another thread which is found at here http://forums.corvetteforum.com/c5-t...em-solved.html
Old Dec 18, 2009 | 01:12 PM
65GGvert's Avatar
65GGvert
It's worth a try if you have access to a soldering iron and solder and can do it without burning the strips or shorting pins together with running solder. I have heard of some accounts where soldering brought them back.
Old Dec 18, 2009 | 01:36 PM
CurbsEnthusiasm
I find the best way to do it is just melt a little solder on the tip of the iron then place it on the contacts.
Old Dec 18, 2009 | 01:47 PM
dlivewyer's Avatar
dlivewyer
Man, that's tiny. I just might give it a try before I order a new one. The worst that can happen is I kill it better.
Old Dec 18, 2009 | 02:06 PM
CurbsEnthusiasm
Seriously I was going to drop the money as well but figured I'd give it a try, the only thing you can loose is your time since the fobs already dead. I'm two fobs ahead right now!
Old Dec 18, 2009 | 02:17 PM
REDEVIL's Avatar
REDEVIL
So, a 2000 key fob will work with a 1999 car? The passive lock feature is worthless anyway. Can someone else confirm the 2000 will work?
Both of my Fobs will not hold the programming for over a few minutes. I program them and they work, but then 5 minutes later, no workie.
Thanks.
Old Dec 18, 2009 | 02:59 PM
65GGvert's Avatar
65GGvert
I promise the 2000 works fine on the earlier models. I've done it myself. It is just missing the switch, all else is the same.
Old Dec 18, 2009 | 03:23 PM
Probably time for a new fob, especially if the battery change didn't make it work again. They do go out from time to time - I had to replace one on my '00.
Old Dec 18, 2009 | 04:04 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
You can also upgrade the entire system to the newer '01-'04 setup. After going through two or three new passive style fobs and a bunch of headache, I did the swap. It does require modifying your wiring harness (unless you can figure out how to jumper the plugs), and new tire sensors - if you are worried about them. Do a search, you should fins some info on the swap.
Old Dec 18, 2009 | 05:29 PM
dlivewyer's Avatar
dlivewyer
Thanks guys for all the help and the quick responses. VERY helpful.
Old Dec 18, 2009 | 09:12 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals. Time to get a new one.
To Key FOB
Old Dec 18, 2009 | 09:35 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Hmm, I didnt think us 99(and older) guys could use the 2000 fob's. I tried the solder but didnt work for me. Its been two seasons without a fob and its getting to me
Old Dec 18, 2009 | 09:37 PM
jrose7004's Avatar
jrose7004
You can find them on e-Bay all the time.
Old Dec 18, 2009 | 09:43 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
You can use a 2000 FOB on a 99, I use a 2000 FOB on my 98 and keep the "original" FOB as a spare.
