Column Lock Bypass
Old Dec 20, 2009 | 03:06 PM
SSTG's Avatar
SSTG
Default Column Lock Bypass
Is there a way to check if theres one already on my car? (i bought it used)
Thanks Guys.
Old Dec 20, 2009 | 03:09 PM
Hammer99's Avatar
Hammer99
When you shut it off and take the key out, does the steering wheel lock or can you still turn it?
Old Dec 20, 2009 | 03:13 PM
SSTG's Avatar
SSTG
I'll have to check the next time I drive it.
I do hear a noise that sounds like a locking mechanism when I shut it off?
Old Dec 20, 2009 | 03:19 PM
SSTG's Avatar
SSTG
Originally Posted by 8VETTE7
That means that either there is no CLB installed OR that one is installed incorrectly.
LOL. So I need to purchase one. How likely is this to happen?
Old Dec 20, 2009 | 03:23 PM
dlivewyer's Avatar
dlivewyer
Or it has had the GM recall done on it. They put a plate to stop the locking mechanism from engaging.
Old Dec 20, 2009 | 04:02 PM
gryphon's Avatar
gryphon
Um, I think mine had a different wiring harness installed. That's what the service bulletin said.
Old Dec 20, 2009 | 05:46 PM
2KFRC5's Avatar
2KFRC5
You don't have to drive it. Just walk out to it, grab the steering wheel and see if it's locked, or if you can turn the wheels. No key needed.
Old Dec 20, 2009 | 06:12 PM
That's the way I would check it.
Old Dec 20, 2009 | 08:46 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Subscribing - I need to do this before I get the car out in the Spring.
Old Dec 20, 2009 | 08:49 PM
SSTG's Avatar
SSTG
So with the bypass,the steering wheel will not lock, period?
Old Dec 20, 2009 | 08:57 PM
2KFRC5's Avatar
2KFRC5
Correct.
Old Dec 20, 2009 | 09:05 PM
SSTG's Avatar
SSTG
Guess i'll be ordering one. Where's the best place to purchase? Thanks.
Old Dec 20, 2009 | 09:32 PM
2KFRC5's Avatar
2KFRC5
Or, post a WTB in the C5 Parts ForSale/Wanted section.
Old Dec 20, 2009 | 09:43 PM
SSTG's Avatar
SSTG
Thanks.
Do you also have a C5??? This issue does not apply to the C6. Just to 1997 - 2000 manual and automatics and 2001 - 2004 manual cars.
It's an 02' Z
What has to happen if does "lock"? Is it crazy expensive to fix?
Old Dec 20, 2009 | 10:35 PM
itzza427's Avatar
itzza427
OK,,to consolidate,,A4's prior to 01,,and all M6 cars are susceptible to problems. IF wheel turns with key out,,you have had a recall done. If wheel turns and you hear the solenoid TRYING to work,,you have had the recall AND do not have an after market CLB. A properly installed CLB bypasses the power to the solenoid thus it is quiet. About $50 for a CLB and about 30-45 min to install!! With a recall done,,they ALSO program a 2mph fuel cut off,,and WHEN the factory recall K harness fails(not if,,WHEN it fails) You will be stranded with a car that WILL start,,just wont go anywhere!!! ASK ME HOW I KNOW,,,Mine had TWO recall fixes before I bought it,,didn't know about hearing the solenoid,,didn't know if it had a CLB,,,,,,,WELL I found out!!!
Old Dec 20, 2009 | 10:38 PM
SSTG's Avatar
SSTG
So why isn't GM utilizing this method? If it is a better option? Not being a jerk,just wondering.
Edit: Just ordered one for $40 shipped.
Old Dec 20, 2009 | 11:03 PM
SSTG's Avatar
SSTG
Thanks for all your input and help on this 8VETTE7. I ordered the bypass.
To Column Lock Bypass
Old Dec 21, 2009 | 09:15 AM
Corvettes of Dallas's Avatar
Corvettes of Dallas
Default Good news and bad news for your C5
Corvettes of Dallas has good news and bad news.
Bad news -- we get orders every day for the Column Lock Bypass.
Good news - we have them in stock ready to get you back on the road.
Please call me direct to place your order.
Todd
Old Dec 21, 2009 | 11:09 AM
itzza427's Avatar
itzza427
GM walked out on this problem back in 2006. They have not spent cent 1 since then on this problem. Afterall it only affects the C5 and that has been out of production since 2004. Further they got off the hook with NHTSA who forced the safety recall by reprogramming the PCM to prevent the car being driven if the BCM thinks the column is locked. The 2mph reprogram is 100% effective in accomplishing that so NHTSA is out of this. The column locking by itself nor the fuel shutoff are safety issues. Prior to the 2mph solution it was possible to drive the car with the column locked under certain conditions. That was in fact a safety issue. The fact that there are many other components that can and will fail and leave the driver stranded is just a "maintenance" issue for the current owner to deal with.
Just a foot note to this,,while there were a few stories of it locking while in motion,,,the column locks up primarily after key insertion,,so they can get away with this solution!! Some have had tuners reprogram 2MPH to like 200 MPH to further insure no problems!!
Old Dec 21, 2009 | 05:59 PM
SSTG's Avatar
SSTG
None of this is a problem with the bypass correct?
