solar battery tender
Old Dec 31, 2009 | 03:44 PM
Terry13's Avatar
Terry13
Cruising
Default solar battery tender
hi,Has anyone tried using a solar battery tender on their corvette.I have my 98 Corvette stored in a garage that has no electric.If you have used one of these tenders,what kind did you use?Thanks for any info.
Terry13
Old Jan 1, 2010 | 02:24 AM
prseasix's Avatar
prseasix
Dude. 9 posts in 2 years? That's some kinda lurking you've got going on.
Go with a plugged in tender. Several cloudy days in a row may leave you stranded, and put a strain on your battery by draining it too low.
Old Jan 1, 2010 | 02:32 AM
DeeGee's Avatar
DeeGee
You haven't filled out your profile so I don't know what climate you have. What may work in NV or TX may not work in ND or VA
I have used one which I think I picked up at Walmart on special. I used to plug it into the truck cigar lighter if I was leaving it at the airport for any length of time. Mind you it was Las Vegas so I could guarantee sun to charge it. All I can say is it always started. Other than testing the voltage across the terminals there's no real indication of how far its topped off the battery, unlike a battery tender that gives a red to green light indication when its topped off.
Old Jan 1, 2010 | 09:33 AM
RedSoxFan's Avatar
RedSoxFan
Do you have a sunny garage?
Old Jan 1, 2010 | 11:08 AM
WvCorvette's Avatar
WvCorvette
Old Jan 1, 2010 | 11:26 AM
waunavet's Avatar
waunavet
St. Jude Donor '20
These are good for boats (in the summer) but hardly worth it for a car stored in a cold garage with sun every three days.
To solar battery tender
