68vette exhaust
Old Dec 31, 2009 | 04:23 PM
highballer's Avatar
highballer
3rd Gear
Default 68vette exhaust
why won't my 68 vette start after replacing entire exhaust system. Had headers Changed to stock manifold & EXHAUST
Old Dec 31, 2009 | 04:28 PM
atmsrus1's Avatar
atmsrus1
Does it turn over or just not do anything when you turn the key?
Old Dec 31, 2009 | 04:37 PM
TraceZ's Avatar
TraceZ
Maybe the wires on the starter were not rerouted / reconnected properly.
Might want to ask a moderator to move this to C2 tech for you. You posted it in the C5 section.
Old Dec 31, 2009 | 08:23 PM
vette.mix's Avatar
vette.mix
A 68 would be the C3 section
Old Jan 1, 2010 | 12:45 AM
itzza427's Avatar
itzza427
68 & 69 almost the same,,,68 the first year of C3. Just for the record that year was just Corvette,,the 1 word stingray returned for 69!! My guess would also be starter wires too!!
Old Jan 1, 2010 | 02:04 AM
prseasix's Avatar
prseasix
What did you forget to reconnect?
Old Jan 1, 2010 | 10:50 AM
highballer's Avatar
highballer
3rd Gear
it turns over for about 4 0r 5 times then dies like I have a weak battery. Installed new battery & it acts the same
Old Jan 2, 2010 | 08:47 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
I would bet it's a bad ground connection
Old Jan 3, 2010 | 12:50 AM
Dave68's Avatar
Dave68
I have had this happen to my 68 during my 22 years of ownership. The exhaust system should have nothing to do with it. If anything, it would've eliminated starter heat soak from the headers. I had to install a high-torque mini starter after getting headers.
Old Jan 3, 2010 | 06:41 AM
Sure hope it is something simple and easily fixed.
Old Jan 3, 2010 | 10:26 AM
highballer's Avatar
highballer
3rd Gear
Thanks Everyone for your inputs the ground was the problem
Again thanks everyone
To 68vette exhaust
