Need Advice -- Poor Wheel Locks
Old Jan 1, 2010 | 11:14 AM
wcdaniel's Avatar
wcdaniel
Default Need Advice -- Poor Wheel Locks
I really did it to myself this time. When I bought the '03 QuickSilver 50th back in September, I was excited and ordered a cheap set of Wheel Locks via the Internet.
They went on just fine.
But now that I need to get the back pair off, it voices the same complaint that my wife usually has:
The 'male' piece is too small and does not make good contact with the 'female' portio of the wheel lock.
So I cannot get them off.
What are my choices from here ??
1. Obviously, don't buy cheap wheel locks.
2. Accept that I cannot make my wife happy. :o
3. Can I just ask my wheel/tire folks to cut-off the poor wheel locks ??
I appreciate anyone's insight and advice.
Old Jan 1, 2010 | 12:22 PM
garage-ghost's Avatar
garage-ghost
Big pair of ViceGrips.
Old Jan 1, 2010 | 12:29 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Gorilla Wheel Locks.
Old Jan 1, 2010 | 01:11 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Les Schwab can remove most wheel locks.
I had it done on my son's 4Runner last month. It runs about $60. I bought new Gorilla Locks and had them installed at the same time.
Old Jan 1, 2010 | 01:21 PM
hotwheels57's Avatar
hotwheels57
Some use an over sized hex socket which is hammered on over the lug nut/wheel lock. SEAR'S sells a set of sockets which bite into the lug nut/wheel lock and work on the same principle.
DISCOUNT TIRE would probably remove them for you for little if anything if you buy a set of chrome or black GORILLA lug nuts/locks from them. They're regular stock items. They're sold in sets of four or twenty with a socket type key which doesn't deform with repeated use like McGARD type locks do.
Old Jan 1, 2010 | 01:22 PM
Indy's Avatar
Indy
Are you sure the key wont go on? I had wheel locks once that were a pain to get the key onto. With a lot of wiggling, it eventually worked.
Old Jan 1, 2010 | 01:26 PM
az57chevy's Avatar
az57chevy
Sears and others sells fastener removal sockets. They have sharp flutes on the interior of the socket that will bite and dig into the stubborn lock. Most tire shops have similar tools. Or if you have a socket that you don't really like you can tap one on that is just slightly too tight/snug and it will usually come off - but the socket might be dinged up.
Old Jan 1, 2010 | 01:38 PM
damilleniumboy's Avatar
damilleniumboy
I opt for option
I sledged hammered the F-out of my hand trying to get a 21mm socket over them, and I failed miserably. Anyhoops, I had my local tire/exhaust place take the locks off my rustang about 10 days ago, and since I'm a re-ocurring customer and talk to the owner they didn't even charged me to have them taken off; I just paid for the mount/remount and balancing of tires. IMHO, I don't really like lock-nuts, so I had them put regular lug nuts on the car. If somebody wants the wheels, they will steal them.
Old Jan 1, 2010 | 01:52 PM
wcdaniel's Avatar
wcdaniel
Yep, I tried it and the male end would not bite on its nor get anywhere near biting with some angled help.
Very frustrating.
I had driven 35 miles to save $40 on a set of tires for the back and now I have to deal with this. Will probably have to drive back there come Saturday morning.
Old Jan 1, 2010 | 02:03 PM
wcdaniel's Avatar
wcdaniel
Originally Posted by damilleniumboy
I opt for option
Interesting. I thought I was the only one that pulls that stuff. I made a full-on hammer of my hand one day. Actually I broke the palate of the hand between the index finger and thumb on my left hand. At least I got one good working hand.
Also, I knew I was in trouble when the Doctor started laughing at the story I told him about how it happened. :o:o
Old Jan 1, 2010 | 02:42 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
4. Post pictures of said wife.
Old Jan 1, 2010 | 07:09 PM
Greg_E's Avatar
Greg_E
Harbor Freight sells a set of two sockets for removing wheel lug nuts. They are around $10 if I remember correctly. Your probably never going to use them again, so you probably don't need the Craftsman set. As mentioned above, any good tire shop should have the tools to get them off.
Old Jan 1, 2010 | 07:12 PM
STL94LT1's Avatar
STL94LT1
My C5 had wheel locks and no key when I bought it. Tapped an undersized socket on the wheel locks, and they spun right off.
Old Jan 1, 2010 | 07:25 PM
westez's Avatar
westez
Women don't like it when the male piece is too small............
Old Jan 1, 2010 | 07:27 PM
ROJ#79's Avatar
ROJ#79
Old Jan 1, 2010 | 07:47 PM
damilleniumboy
Yup, I couldn't grip anything with my tumb either for a couple of days. Eveyone at worked laughed when I told them the story too. I think what helped me a bit is that I used to teach Karate, so my nuckles are kind of harder? Buy boy I felt like I was going to faint. I still have a small bruise on the side of my nuckle from ten days ago when I hammered it.
Yup, it's like when you buy a bolt extractor. It never gets used again. Also, I think you can go to a tire changing place and have a new key ordered for <10 bucks. I know they do it in another tire shop here in town, so you might want to check in to that.
To Need Advice -- Poor Wheel Locks
