HELP......Buzzer sound???????
Old Jan 1, 2010 | 04:12 PM
redvette365's Avatar
redvette365
Default HELP......Buzzer sound???????
I just went into my garage and heard a noise coming from my 2001 Z06.
(the car is off and keys out of the ignition)
It sounds like a buzzer going off somewhere in or behind the glove compartment. It went off after a few minutes.
Does anyone have any idea what it could be???
Old Jan 1, 2010 | 04:27 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Did it happen before you turned the car off or after?
Old Jan 1, 2010 | 04:45 PM
redvette365
The car was not on. I went in the garage , opened the car door and the noise started. It sounded like a buzzer or a real fast relay.
Old Jan 1, 2010 | 05:06 PM
damilleniumboy's Avatar
damilleniumboy
I think your battery is almost dead. It happened on mine, and it was very low. The relays start clicking/chirping, and the door locks stared to lock/unlock by themself.
Old Jan 1, 2010 | 07:17 PM
redvette365
That may be it. My car wouldn't start the other day, the battery was too weak.............Thanks for the info.
P.S. you look just like Jennifer Anaston (LOL)
Old Jan 2, 2010 | 03:46 AM
DeeGee's Avatar
DeeGee
It sounds like classic dead battery symptoms
Theres a relay in the passenger footwell area that chatters when the battery is low. Its not quite a buzzer but I'm sure thats it.
If you have a lead acid battery you may get away with an overnight charge. If it's a Red Top (AGM) you've probably killed it already. Once batteries start to go it may just be better to replace it. Theres a constant drain on the C5. You might want to consider a battery tender if the car's not a daily driver.
Old Jan 2, 2010 | 09:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. Either the battery is down real low or one of the seat switches might be bad causing the seat to run.
Old Jan 2, 2010 | 09:42 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
Don't touch the sides :
Old Jan 2, 2010 | 11:02 AM
damilleniumboy
Yeah, she is pretty hottttt! I'm not haha.
Old Jan 2, 2010 | 11:43 AM
redvette365
You guys all nailed it. (Battery) Thanks for all of your help.
To HELP......Buzzer sound???????
