M6 Transmission question
Old Jan 5, 2010 | 09:49 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default M6 Transmission question
I was told that the 04 Vette M6 is a Tremic tranny. What year did GM start using the Tremic in the Vette?
Old Jan 5, 2010 | 09:56 PM
rustyguns's Avatar
rustyguns
Originally Posted by len90vette
i was told that the 04 vette m6 is a tremic tranny. What year did gm start using the tremic in the vette?
2008 T6060 but the 2004 t56 is better
Old Jan 5, 2010 | 10:17 PM
ALLEGRO's Avatar
ALLEGRO
The T-56 is a bullet-proof unit manufactured by Borg Warner for many applications such as the Viper, Corvette, Aston Martin and even the Mustang Cobra. Some data indicates that since 1998 it was built by Tremec.
Old Jan 5, 2010 | 10:21 PM
65GGvert's Avatar
65GGvert
Tremec made all the manual transmissions in the C5's. MN6 and MN12 (T56).
Corvette 6-speed manual transmission.In the 1990s, Corvette manual transmissions were equipped with the Computer Aided Gear Selection to meet fuel economy requirements. It required the driver to shift directly from first gear to fourth under low speed conditions. In 1997, the rear-mounted Tremec T56 6-speed manual transmission replaced the traditional mounted Borg-Warner T56 to provide a 51/49 weight distribution of the car and to handle engines capable of 600 horsepower.
Today
The TR6060 6-speed manual transmission.In the early 2000s, the Tremec T56, weighing 121 pounds, were placed in Cadillacs and Corvettes powered by the 6- and 7-liter V-8s. In 2008, the TR6060 6-speed manual gearbox replaced the T56 and helped improved the 0-60 mph run times to 4 seconds.
Old Jan 5, 2010 | 10:22 PM
damilleniumboy's Avatar
damilleniumboy
Are the t56 interchageable between the T3 Cobras and the Vettes?
Old Jan 5, 2010 | 11:30 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Well now I'm not so sure about the years. I was told by the dealer and asked other questions at the factory later, but supposedly BW manufactured the tranny for '97 and '98 and Tremec past that. My '99, I somehow got a BW tranny which cause me numerous headaches and expensive repairs. Supposedly the '99's and forward were supposed to get Tremecs.
Old Jan 6, 2010 | 06:24 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Thanks for the info guys.
Old Jan 6, 2010 | 07:11 AM
AU N EGL's Avatar
AU N EGL
Should be with slight different mounts.
Now the Cobras used the front mount behind the engine and clutch trans and the vettes used the rear mount so that may be the difference
Old Jan 6, 2010 | 07:33 AM
oakvillec5's Avatar
oakvillec5
very interesting
Old Jan 6, 2010 | 08:18 AM
Oldvetter's Avatar
Oldvetter
Aren't the Tremec and Borg Warner Transmissions, installed in C5s, the SAME DESIGN, just manufactured by different companies?
Old Jan 6, 2010 | 08:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
How do you see that ?
The T6060 has heavier (thicker gears) and a stronger cluster, etc ....
Old Jan 6, 2010 | 08:40 AM
Oldvetter's Avatar
Oldvetter
Also has three synchros instead of 2 on some gears ! The shift mechanism has been revised to shift better.
As noted, it can handle more power.
Old May 12, 2010 | 11:49 AM
97C5driver's Avatar
97C5driver
any confirmed correct info about this thread? it seems to be all over the board.
i just had my 97 6 speed pulled & its a borg warner.
Old May 12, 2010 | 01:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It should be a Tremec which is actual Borg Warner..
Old May 12, 2010 | 01:09 PM
97C5driver's Avatar
97C5driver
i thought borg warner & tremec were 2 different companies?
Old May 12, 2010 | 01:12 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Scroll down to the transmission section.
http://www.corvettemuseum.com/specs/2001/specs.htm
To M6 Transmission question
