Dexcool antifreeze
Old Jan 6, 2010 | 08:24 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Default Dexcool antifreeze
If you need any, Autozone has a buy one get one free after rebate. Can get either 50/50 or full strength.
Old Jan 6, 2010 | 09:29 AM
jrose7004's Avatar
jrose7004
Hey, thanks!
Old Jan 6, 2010 | 01:38 PM
Thanks for the info. I need to do a coolant change, so this will come in handy.
Old Jan 6, 2010 | 01:42 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Anybody have an opinion or know which is better to use, the full strength or 50/50? I know you don't use the coolant at full strength, but does the C5 require a 50/50 mix?
Old Jan 6, 2010 | 01:46 PM
Mike98SilVert's Avatar
Mike98SilVert
Old Jan 6, 2010 | 01:50 PM
Steve20's Avatar
Steve20
if you use the 50/50 you do not have to buy distilled water at about a buck a gallon. If I were doing a complete flush, I'd use the full strength and add distilled water. If I was just doing a drain and refill, I'd use the 50/50 already mixed stuff
Steve
Old Jan 6, 2010 | 01:56 PM
Too-Fast's Avatar
Too-Fast
Thanks Steve.
Mark
Old Jan 6, 2010 | 07:31 PM
itzza427's Avatar
itzza427
Ok,,I'll ask(I know there are more out there that want to know) Just how much do we need for a flush. I can blow out the block and have the equipment to "BURP" the motor!! Just need to know how much for a full fill!!
Old Jan 6, 2010 | 07:49 PM
Shylor's Avatar
Shylor
I'm curious why you'd do it this way?
Old Jan 11, 2010 | 05:55 PM
itzza427's Avatar
itzza427
Anybody out there know this answer???
Old Jan 11, 2010 | 06:56 PM
tigers123's Avatar
tigers123
Default fyi
http://www.consumeraffairs.com/news0...m_dexcool.html
Anybody familiar with this?
Old Jan 11, 2010 | 07:18 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Originally Posted by tigers123
My son works in a local shop around here he came home told me if I have it in my car I should get it out because of some things he has seen at his shop.
I haven't changed it I figured if it would mess up our cars I would have seen more post about it by now. I hope its OK if not I'm sure someone will chime in.
Old Jan 11, 2010 | 09:14 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I'm a little leary about using Dexcool since reading some negative threads about it on this forum.
I think I'll hold off until I have more facts.
Old Jan 11, 2010 | 09:30 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
There is nothing wrong with Dexcool at all, It can't be beat, Just use as stated and use distilled water and it will last for years. Most that had troubles with is mis used it or used tap water. Operator error.
Old Jan 12, 2010 | 12:30 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
It must just be in Indiana. I didn't see it listed on their website for KY.
Old Jan 12, 2010 | 12:54 AM
tigers123's Avatar
tigers123
There are just too many stories about problems related to this coolant. It may not be the direct cause of any problems, but you never hear of that many problems with the green. Do a google search of the problems related to this coolant. I believe it is a combination of factors, but I believe going to the green with a totally clear flush to distilled water in between is a better choice.
Old Jan 12, 2010 | 01:22 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
See, hearing stuff like that spooks me.
To Dexcool antifreeze
Old Jan 12, 2010 | 01:47 PM
TEXHAWK0's Avatar
TEXHAWK0
I think most of the problems reported with Dexcool are due to improperly maintained cooling systems, where air gets in the system. I have found that it also may have something to do with the design of the cooling system. I have a Malibu, and it forms a brown film in the overflow tank no matter what I do, but on my Impala and Corvette, the Dexcool always drains out perfectly clean. The Corvette has a fully pressurized surge tank, and the Impala has a tank vented to atmosphere with the cap on the engine. The Malibu has a pressurized tank similar to the Corvette, so it is not obvious what causes the film to form.
For the ones wanting to do a complete flush, the system holds 12 quarts. When I drain mine, I get about 8 quarts out, leaving about a gallon in the block. I usually just do not let mine go over 2-3 years, and replace what I can drain.
The 50/50 premix would be great if it did not cost twice as much. The bottles I have seen cost the same as the full strength Dexcool, and you are paying for 50% water. Just buy a gallon of Dexcool and a gallon of distilled water, and make 2 gallons.
Old Jan 12, 2010 | 06:32 PM
killain's Avatar
killain
Oldtimer
The chemical construction of 'DexCool' is a perfect product. BUT, the coolant MUST be changed every five years on time. Not six or eight or any other time span. ALSO, DexCool, once installed in your car, needs to be isolated from the open air. So the first thing is to do a complete and through flush and the inspect your whole cooling system, replace any possible bad hoses or leaky radiator seams, heater core, ect. That is necessary because once the DexCool coolant mixes with air, it starts to degrade.
It's not like the old days where if you had a minor leak, you could just top off the expansion tank or radiator. DexCool, Once it mixes with air, it's going to be a very short path to engine trouble. And that's not GM's problem, you as the cars owner is/are responsible to once in awhile to look the car over. That includes making sure the overflow tank isn't empty, by then it's too late. And it's not like we can go back to the green stuff, it is being phased out by the EPA, who mandated the change to DexCool a number of years ago. So I don't like it either, but we have no choice.
Old Jan 18, 2010 | 09:46 PM
DAVIDZ06's Avatar
DAVIDZ06
Default Flush?
At what frequency is flushing recommended? I have a 2002 w/ 76k, and I doubt that the coolant has ever been changed. I know I haven't anyway. Lately I have noticed a water temperature increase when running the heater (235-245 degrees), but it levels out to about 200-212 when driving normally. Advice?
