rear stainless letters
Old Jan 6, 2010 | 02:08 PM
v1 rot8's Avatar
v1 rot8
Default rear stainless letters
Has anyone ever removed and re-applied the stainless letters? If so,,,how? The bottom right corner of the R sticks out just enough to catch the towel. Rest of the letters are perfect. I think if I could get it off safely then I could file that sharp pointed corner off some. Guess I would need some new 3M tape too, anyone on here sell the tape? Thanks guys
Old Jan 6, 2010 | 07:53 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Take it out, clean the back of it real well (and the indent) and apply
3M double-sided tape to the back of the letter. Then use a razor to cut the tape so that it conforms to the letter. Peel the plastic off, then re-apply.
Old Jan 6, 2010 | 07:54 PM
jrose7004's Avatar
jrose7004
Old Jan 6, 2010 | 08:26 PM
vette.mix's Avatar
vette.mix
X2
Old Jan 6, 2010 | 08:42 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Use alcohol - rubbing kind To clean the car and the part then reapply!
Old Jan 6, 2010 | 09:02 PM
aschiftner's Avatar
aschiftner
That is a lot of tape per area on those inserts. I could understand being worried about the paint possibly peeling?????
I would use some lighter fluid or goo be gone to assist breaking down the adhesive properties of the tape just to be safe. Applying with a surienge would probably be optimal. R/ Al
Old Jan 6, 2010 | 09:33 PM
Works like a charm - just be sure you don't scratch the outside surface of the letter up when doing all this. Don't ask me how I know that.
Old Jan 6, 2010 | 10:22 PM
williams.jerry45's Avatar
williams.jerry45
got the same problem, how do you get the letter off the car with out breaking it or messing up the paint??
Old Jan 6, 2010 | 11:40 PM
4440stevesvette's Avatar
4440stevesvette
If you or a friend has access to a Dremmel , I would use that to round off a sharp corner of a letter. They make some very small drum sanders that should work just fine. Just be sure to put some tape around the letter for protection of the paint and USE A STEADY HAND!!! Good luck.
Old Jan 7, 2010 | 04:09 PM
williams.jerry45
could you get a SS letter off using a hair dryer?
Old Jan 7, 2010 | 04:32 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Yes, that's a good way to soften the glue and aids in removing
Nick
To rear stainless letters
