Shifter boot ring question
Old Jan 7, 2010 | 05:16 PM
TKT-MKR's Avatar
TKT-MKR
Default Shifter boot ring question
Hey all,
Ok I have been trying to look for a shifter boot and ring combo but I am bombing out. Basically getting the "back order with no eta" response.
So here is my question.....
What is the difference between the 6 speed model C5's mounting ring over the 97-04 years?
I mean could they have really changed it that much considering the center console doesnt look to have changed any.
Please help. Pictures would be great!
Old Jan 7, 2010 | 05:42 PM
hotwheels57's Avatar
hotwheels57
I'm pretty certain that the plastic retaining ring on the shifter boot from '97 through '04 manual transmission cars are all the same.
The problem is the retaining ring isn't available separately from GM so you have to order the C5 vinyl boot/ring as an assembly. It's not inexpensive.
You might get lucky and find one at a salvage yard or through the forum classifieds. I've seen them sell for $20 here for just the ring.
Old Jan 7, 2010 | 05:51 PM
TKT-MKR's Avatar
TKT-MKR
thats what i thought, but gene at gmparts telling me they arent the same
i dont care about getting a new boot i just wanna be able to mount it
Old Jan 7, 2010 | 06:09 PM
hotwheels57
Gene would know better than me then...
Old Jan 7, 2010 | 08:08 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Hey all,
What is wrong with the old ring? I am running a new boot on my old ring that broke during the switch out I did. The old broken ring is holding up just fine. A tiny bit of glue and well placed stables for the new boot has survived several removals and reinstalls for other mods!
Old Jan 7, 2010 | 08:16 PM
TKT-MKR's Avatar
TKT-MKR
Well because the way this boot, ring shifter ****, and shifter went ii it is it all glued together. The ring is busted and when it comes out it will be busted and also all one piece with the shifter assembly. So I am trying to find a way to get a new setup for the new shifter and **** assembly i have going in.
Old Jan 7, 2010 | 08:17 PM
Dominic Toretto's Avatar
Dominic Toretto
I reused the stock one from my original boot.
-Alex
Old Jan 7, 2010 | 08:20 PM
Jet-Jock's Avatar
Jet-Jock
Looking at parts list for the components, it appears that 99-04 are the same and 97-98 are the same.
Old Jan 7, 2010 | 08:25 PM
Silverbullet00
Guess you will have to try suggestions above as well as searching the C5 parts forum for "parting out".
Good luck!
Old Jan 7, 2010 | 09:50 PM
Would be nice if the ring was sold separately, but at this point, GM sure won't be bringing it out. And not sure it would be profitable for an aftermarket company to do it either.
To Shifter boot ring question
