blinker fluid.
Old Jan 9, 2010 | 06:52 PM
memphis_vette's Avatar
memphis_vette
Default blinker fluid.
my blinkers don't seem to be flashing fast as they use to be. does any one know how to change the blinker fluid?
Old Jan 9, 2010 | 06:59 PM
memphis_vette
sorry guys that wasnt me. friend of mine. told him he was low on blinker fluid so he asked on my forum. he is not very mechanic friendly.
cody
Old Jan 9, 2010 | 07:25 PM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Tell him he needs to rotate the air in the tires.
Better check those muffler bearings too!
Old Jan 9, 2010 | 07:26 PM
Carcass's Avatar
Carcass
Well,if he's going to change the fluid,he might as well go with synthetic ,and be sure and have him rotate the bulbs while he's in there-and don't forget to adjust the palpitator,or he'll be doing it all over again real soon.
And remember to never install a left bulb on the right side,or vice-versa-I did that once,and it "not be pretty"
Old Jan 9, 2010 | 07:28 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
cody
Bad luck. It appears to be out of stock.
http://kalecoauto.com/index.php?main...&products_id=6
Old Jan 9, 2010 | 07:34 PM
Aerovette's Avatar
Aerovette
I have only done this a few times and have written an extensive "how to" but I lost the "how to" link. If I recall, the car is attached to a rotisserie and rotated a full 360 degrees to pick up any old fluid residue within the blinker (Drain fuel first).Then another 180 degrees so you are looking at the bottom of the car. Remove the driver's side door and you will see inside the fender well, a small drain plug. This is not it, but it looks cool huh? Now that you know what it looks like, put the door back on and turn the car right side up and remove from rotisserie. With a blow dryer, melt away the seal that holds the front license plate cover on and set it aside. Cut a hole behind the cover large enough to place your hand in. reach in about elbow deep while grasping either skid rail. Have a friend start the vehicle and drive for several miles until you no longer feel the need to change the fluid. Congratulate yourself on a job well done.
Old Jan 9, 2010 | 07:43 PM
SSTG's Avatar
SSTG
Where do you find the dipstick?
Old Jan 9, 2010 | 07:50 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Old Jan 9, 2010 | 08:43 PM
rdwiv's Avatar
rdwiv
OMFG! I would have bet real $$$$ such a thing did not exist...AND out of stock!
Old Jan 9, 2010 | 09:05 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
No dipstick on the vette's, just a line you fill to.
Old Jan 10, 2010 | 12:40 AM
Jistari's Avatar
Jistari
Ya know, being the somewhat sarcastic pita that I can be at times, I was going to write up a post, but Im not feeling well today, and I do appreciate you taking care of that for me Aero .
Old Jan 10, 2010 | 02:22 AM
Baron138's Avatar
Baron138
I changed mine with synth years ago, and I added the high perf weather seal too. Increased my flash ratios by 4 F.P.M. thats equal to 12 hp on the dyno. Its a have to mod!!!!!
Old Jan 10, 2010 | 02:26 AM
SCM_Crash's Avatar
SCM_Crash
Problem is usually related to the turbo encabulator. Make sure you check that first.
Old Jan 10, 2010 | 02:49 AM
memphis_vette
haha the turbo encabulator from the Chrysler training video.
Old Jan 10, 2010 | 03:07 AM
dieseldave56's Avatar
dieseldave56
Default European..............
I use the GM OEM fluid but swapped the stock bulbs for the new European ones, much faster blinker now.
Old Jan 10, 2010 | 10:31 AM
Lancejoker's Avatar
Lancejoker
Could be worse. His just blink slow. I tried to order some money and order the fluid from China. My blinkers don't work at all now.
Old Jan 10, 2010 | 10:36 AM
hattitude's Avatar
hattitude
While you're in there, add a blinker seal........ worth at least 10HP..
To blinker fluid.
Old Jan 10, 2010 | 10:45 AM
jrose7004's Avatar
jrose7004
Tell him that theres an embargo on it from Iran!
Old Jan 10, 2010 | 10:53 AM
nadj99's Avatar
nadj99
If you use this method you will surely have many issues down the road. The dipstick is removed because you use your finger as a gauge. FILL the oil until you can stick your finger in the cap and you feel the oil. Only then it is completely full. No air can get in there and cause that ol famous valve flutter.
Old Jan 10, 2010 | 11:11 AM
itzza427's Avatar
itzza427
While on the site,,,I liked the single exhaust "O" pipe!!! With our V8's we can hang a pair of them on!! Just imagine the performance gain there!!! Should be many times lighter than even the Ti exhaust!!!
