Cam only guys, do it again??
Old Jan 15, 2010 | 03:11 AM
jd86L98's Avatar
jd86L98
Originally Posted by AU N EGL
your cam would be a good choice. But you will need new springs as well
and new timing chain,
Going with new pushrods too and probably a new oil pump.
Old Jan 15, 2010 | 07:42 AM
AU N EGL's Avatar
AU N EGL
Good Idea.
:Let us know how it goes.
If you can do a before and after dyno runs that would be great to see comparisons.
Old Jan 15, 2010 | 10:09 AM
jd86L98's Avatar
jd86L98
Good Idea.
That would be the plan. I am shooting for 380rwhp with ARH (1 3/4 w/cats) and underdrive pullley. Already have GHL bullets and Vararam. Anything less and I will be disappointed.
Old Jan 15, 2010 | 11:20 AM
AU N EGL's Avatar
AU N EGL
Underdrive pulley if you can. That will reduce some rotating weight and up a ponie or two.
Good Luck
Old Jan 15, 2010 | 11:44 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I m on my second cam, still stock heads and love it , making 435 RWHP, go big when you get the cam,
Old Jan 15, 2010 | 02:02 PM
SpeedyRCM_TX's Avatar
SpeedyRCM_TX
I've driven and ridden in Mojo's vette many times and can tell you it is easily driveable. It behaves great and gives a nice shake at idle. Then under WOT it is
Old Jan 15, 2010 | 02:45 PM
angman5's Avatar
angman5
I don't have to drive mine everyday so I would not only do it again but go with a T-REX cam next time.
If you have to drive it every day 232-236 is about as big as you want with a M6 with an A4 a little less unless you have a good stall converter. Here is a sound clip of mine
http://www.youtube.com/watch?v=uomZr1KNUu0
Old Jan 15, 2010 | 03:28 PM
mojo1's Avatar
mojo1
Have to drive everyday? You mean get to I dont have to drive mine daily but I sure do and love it . I have the Englandgreen MayhemII , dont know the specs but it is not a baby cam.....
Old Jan 15, 2010 | 03:31 PM
Jistari's Avatar
Jistari
Im sorry, I read the title as "can only guys do it again?"
Old Jan 15, 2010 | 05:01 PM
jedblanks's Avatar
jedblanks
Cam Specs?
Intake duration @ .050: 228
Exhaust duration @ .050: 232
Intake lift .588
exhaust lift .575
LSA; 113*
I'd go higher LSA if I had it to do again. 114/115 probably.
Old Jan 15, 2010 | 06:23 PM
jd86L98's Avatar
jd86L98
Intake lift .588
exhaust lift .575
LSA; 113*
The 228/232 was my second choice and is still in consideration
Old Jan 15, 2010 | 08:59 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I loved my cam only, don't know exact specs...114 230's under .600. I gained 68 rwhp (430rwhp stock intake and un-touched heads) with my existing bolts ons(ie headers hi flow cats) The cam is the "GeorgeZ"cam at ECS. I'm now heads and cam with more cubes (forged 402) and i like it even more.
Old Jan 15, 2010 | 09:24 PM
  #33
jd86L98's Avatar
jd86L98
Sounds good, what RPM are you idling at?
Old Jan 15, 2010 | 09:28 PM
  #34
jd86L98's Avatar
jd86L98
I just read through your thread with comments from Charlie at RPM, very impressive. What are the street manners like especially highway cruise in sxith gear?
I am in So.CA as well but was going to have Ryan at CMS do the work. Both CMS and RPM have excellent reputations and CMS is a lot closer to me.
