HVAC actuator/0367 Error question
Old Jan 17, 2010 | 06:13 PM
mistermog's Avatar
mistermog
Default HVAC actuator/0367 Error question
Hi all,
I'm still having the warm/hot on the driver side, cold on passenger side.
I've read all the posts on this but still haven't seen this particular combination.
I have the B0367H error (it never says current? odd) which is the Passenger side actuator, but the passenger side air is ICE cold. Its the driver side that never cools down. No other codes.
Could this mean I am having an issue with the passenger side AND that the driver side is broken but not throwing codes?
I have to take off the dash one of these days to fix my busted HUD post issue, so i was going to see if I can do something about the AC then.
I am just not sure if it is possible to have the right side codes but have the left side be the one not working? Anyone?
Old Jan 19, 2010 | 06:46 PM
mistermog's Avatar
mistermog
bueller?
Old Jan 19, 2010 | 06:51 PM
scottydog's Avatar
scottydog
I would replace the passenger side actuator.
Old Jan 19, 2010 | 07:18 PM
mistermog's Avatar
mistermog
I do have to get into the dash to fix the HUD problem, I was wondering if they are easy to take out, to swap the pass/driver side and see what happens then?
I just think its weird Im getting a passenger side code, and a driver side hot air... I haven't found any thread anywhere that said the same issue, its always the driver side that is giving codes.
To HVAC actuator/0367 Error question
