2002 reliability
Old Jan 18, 2010 | 11:55 AM
vette-oholic's Avatar
vette-oholic
Default 2002 reliability
A friend of mine is looking at a 2002 base c5.
Is there anything specific to look out for for those years with reliability, etc?
Thanks.
Old Jan 18, 2010 | 12:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Nothing out of whack with 2002 (or any year) in particular.... just the normal C5 issues.
There is literally DAYS of reading on the little issues commong to this generation just like any other.
Old Jan 18, 2010 | 12:35 PM
aschiftner's Avatar
aschiftner
The column lock issue is gone from what I've read about the 2002 Vette's. I like mine!! R/Al
Old Jan 18, 2010 | 12:55 PM
Jet-Jock's Avatar
Jet-Jock
Only for automatics 01-04 A4, 97-04 MN6 are all affected by ECL recall.
02 gets all the improvements from 01, but not into the 03-04 issues that pop up some related to C6 parts being introduced.
It's all a crapshoot. One can be fine another a nightmare.
Old Jan 18, 2010 | 12:56 PM
CAP94's Avatar
CAP94
I have a 02 and can't really think of any issues. It all depends on how well the car was taken care of.
Old Jan 18, 2010 | 01:10 PM
utownal's Avatar
utownal
I bought my 2002 new in 2001. No major problems. I had a leak on the driver's side
rear end at 3,000 miles which was repaired under warrenty. I currently have 25,000 miles
and no problems. I think all of the earlier year issues were solved by 2002.
Old Jan 18, 2010 | 03:28 PM
WvCorvette's Avatar
WvCorvette
Old Jan 19, 2010 | 04:33 PM
vette-oholic
thanks everyone.
Old Jan 19, 2010 | 04:53 PM
rboineau's Avatar
rboineau
Although you may well know about this, on any year C5 be sure and look carefully underneath--particularly at the front--for damage from scraping, improper lifting/jacking, etc. Not a reliability issue but you should check. Also learn how to read the trouble codes off the dashboard--the information is here on the forum--that may alert you to problems with the car. Try to find out what has been done re the electronic column lock as this is a constant source of trouble on the C5s
Old Jan 20, 2010 | 12:05 AM
Mile High C5's Avatar
Mile High C5
My 2002 MN6 Coupe has 25,000 miles and has had ZERO problems. I put the column lock bypass from Corvettes of Houston as a pre-caution.
Thanks.
Old Jan 20, 2010 | 12:08 AM
Stavesacre21's Avatar
Stavesacre21
This thread was posted just awhile back where one person went on about 2002's being the best year. Not really quoting validity by any means, but it's worth a read if you're concerned. A lot of good points as the thread goes on.
Old Jan 20, 2010 | 05:03 AM
Look for the usual things - rocking seat, rear differential seal leaks, column lock recalls done, etc. I've got a Corvette Buyers Checklist in a Word file and if you'd like a copy, PM me your e-mail address.
Old Jan 20, 2010 | 05:30 AM
JCFILM's Avatar
JCFILM
2002 = outstanding yr.
Old Jan 20, 2010 | 05:47 AM
dieseldave56's Avatar
dieseldave56
Default If you have to ask...........
then take a person who knows the C5, even if you have to pay them.
Old Jan 20, 2010 | 07:05 AM
DeeGee's Avatar
DeeGee
I had many of the common problems in the first few years.
Leaky diff, dead battery, new RDLCM, new EBCM
Its been very reliable recently. 02 was a good year IMHO
Old Jan 20, 2010 | 08:10 AM
GFCmgb71's Avatar
GFCmgb71
I have an '02 and its been absolutely problem free for 10k since i got it, couldn't be happier. I do have the leaky diff syndrome though, looks like i'll just have to get chuck cow 4.10's! oh well
Old Jan 20, 2010 | 08:16 AM
Tom Keitzer's Avatar
Tom Keitzer
I agree. Have an 02 vert and the only problem I've had in 30K miles was the left headlight motor gear stripped out. Replaced it myself, no big deal. Great car.
To 2002 reliability
Old Jan 20, 2010 | 08:19 AM
2003 electronblue's Avatar
2003 electronblue
Yes check the seals gm put out a bulleten on the bad seals and useing only one seal and a special sealer to be used...the mechanic will never get it done right the first time it will take at least three attemps to get it fixed.. if u can buy a warranty by all means do other wise vette repairs will cost u more then what u will pay for the car in your first year of ownership..
Old Jan 20, 2010 | 09:35 AM
Rollin's Avatar
Rollin
I have put 40 of the 70k miles on mine and except for the column lock the only issues have been minor and this forum has been awesome in helping figure them out and let me know how to fix.
Old Jan 20, 2010 | 09:54 AM
4 KRUSIN's Avatar
4 KRUSIN
It's important to know that the column lock recall did not fix the problem. If the car is an M6, the only solution is the Column Lock Bypass. They are cheap and effective and can save a large bill in the future.
