[Z06] Suspension time
Old Jan 21, 2010 | 04:40 PM
bmg's Avatar
bmg
Cancel your order!!!!
Old Jan 21, 2010 | 04:44 PM
Z06 Pack's Avatar
Z06 Pack
I just talked to Joe at Zip Corvette about it. Apparently even with the Bilsteins, you can still bottom out the shocks on a lowered car. I used to have a 2004 M3 with springs on stock shocks that used to bottom out ... it made the car not even worth driving.
I think I'm going to cancel and get the coilovers!
Old Jan 21, 2010 | 04:45 PM
ZEE-OH-6's Avatar
ZEE-OH-6
Originally Posted by ZO6 Pack
Why do you guys have to make me regret my decision of not getting coils!
I know money is hard to come by these days ( approx. $2,000.00 installed ) but I did it for safety reason. We all want the car to go fast a stop fast but it has to stick to the road to
Old Jan 21, 2010 | 04:51 PM
bmg's Avatar
bmg
Old Jan 21, 2010 | 06:23 PM
95wht6spd's Avatar
95wht6spd
Originally Posted by ZEE-OH-6
You will LOVE them ! They are height adjustible so you can set the height on each wheel eaxtly where you want them and they have 16 damper adjustments to get the ride just right for your use. And if you are really **** you can corner balnce the car with them and the right suspension shop to help with the scales !!!
Since you completely remove the stock springs you have REAL 4 wheel independent suspension !
So you took your sway bars off too.....
Old Jan 21, 2010 | 06:25 PM
95wht6spd's Avatar
95wht6spd
For the guys that have coilovers, does it ride better on the street as far as comfort, or does it just feel like it handles better?
Old Jan 21, 2010 | 06:37 PM
bmg's Avatar
bmg
handles better and rides better (more suspension travel)
Old Jan 21, 2010 | 06:54 PM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
I don't know, I put on my Pfadt coilovers last month and I am waiting for spring. Stupid winter!
Old Jan 21, 2010 | 07:06 PM
ZEE-OH-6's Avatar
ZEE-OH-6
After everything is said a done, Pfadts installed, drive around for a week and let them settle, take measurements on how you want your car ride height at each wheel, jack up car / remove wheels adjust each Pfadt to you determined setting ( ride height ), set your dampers to 6 for now, get it 4 wheel aligned - NOW drive it up on a ramp so the car has its full weight on all 4 wheels and the car is level - disconnect your sway bar end links to see if they ( sway bars ) are neutral - they should not be bidding or twisted if neutral - reconnect end links ( you may need adjustable ? ) - DONE, now drive it like GOD wanted you to drive it
Old Jan 22, 2010 | 10:51 AM
Z06 Pack's Avatar
Z06 Pack
I canceled the order for the shocks, my bank account hates you guys ... but I'm sure once I get the coilovers installed I'll be able to forgive.
Has anyone installed these themselves?
Old Jan 22, 2010 | 10:53 AM
vinceg's Avatar
vinceg
Default Say bar's
Your right on Tim, U B a smart guy. Doing this there is NO deed for scales unless you are moving weight to balance.
Old Jan 22, 2010 | 10:54 AM
BitViper's Avatar
BitViper
... my bank account hates you guys ...
hahahaha.. I like that
Old Jan 22, 2010 | 11:23 AM
  #33
ZEE-OH-6's Avatar
ZEE-OH-6
Vince your are the master and I am just the student
grasshopper
Old Jan 22, 2010 | 11:32 AM
  #34
ZEE-OH-6's Avatar
ZEE-OH-6
They come with good instruction and I know people who have done it themslves but mine was a install special with the purchase of the Pfadts, $1,800.00 out the door. But you get what you pay for, I had to set the ride height to where I wanted it afterwards and re-torque the loose bolts to the right settings and add lock-tite as called out in the instructioin manual
Old Jan 24, 2010 | 10:32 PM
  #35
Z06 Pack's Avatar
Z06 Pack
Buying the Pfadt's next month. After I pay for this damn vacation my girlfriend wants to go on.
Old Jan 24, 2010 | 10:39 PM
  #36
ZEE-OH-6's Avatar
ZEE-OH-6
When it's all said and done and finally sinks in you will have realized like us all that it's probably the best thing you did to the car for the cost
Old Jan 24, 2010 | 10:58 PM
  #37
Z06 Pack's Avatar
Z06 Pack
I think you're right. Thanks for the advice.
Old Feb 2, 2010 | 11:51 AM
  #38
Venomized03's Avatar
Venomized03
I will be ordering a set of the coilovers this next week coming up. Do you think they will help with launching at the 1/4 mile and on the street? I was thinking I could probably just loosen up the travel whenever I know Im going to the track I guess
Old Feb 2, 2010 | 12:18 PM
  #39
ZEE-OH-6's Avatar
ZEE-OH-6
Whom ever you are buying the coilovers from I would ask them this question ? I know that when I adjust my Pfadts at a lower setting I get mote traction.
