Does anyone have any good dimensions or photos of a custom adapter they had built to go between their floor jack and the rear crossmember to lift the car by the appropriate jacking points? Guess I need to get one welded up?
The cross beam adapters are adjustable. I have one set up (fixed width) for the front and another set for the rear. They have a pin on the bottom center that fits right into my 3 ton floor jack. I did a search and every place I found was out of stock. I don't know if that means they have stopped making them or not.
Hope this helps.
Hope this helps.
Yeah! That's what I was looking for, but you're right, it looks like they are out of stock?
Here's what I had made - an 8"x8", 1/4" thick piece of steel plate that I place on the jacking pad. I then lift from the center of the crossmember. Has worked fine for years.
Just slide the jack under the center of the cross beam and lift it up. It is not going to hurt your car
why do so may people say this is a bad idea? it looks pretty sturdy, i wouldnt think it would be a problem. i still use a peice of wood just to be safe.
Isn't it better to lift supporting the entire cross member instead of at just one pressure point, that being the center? Wouldn't spreading the support across the entire cross member lessen the risk of it cracking? Just seems safer to me doing it this way.
In theory yes, but your not going to crack anything. I've done it a few times when i didn't have my trusty 2x4 around. You won't hurt a thing.
Several guys that go to the track every weekend and are swapping out wheels don't use anything. I've never seen or heard of any probs.
Its not going to crack it. Just jack it up then put jack stands underneath each side.
i've never used anything for mine.. the crossmember is pretty damn structurally sound.. if it offers peace of mind, then toss a board under there.. if not, it won't hurt anything.. my opinion anyways
you can do the same. As long as it looks like the pad will fit on there and not slip off. I have jacked it up without but i like to use a 2x4 if i have one.
What about jacking up the front of the car? Do you still need something under the front crossmember to jack it up?
I drive the front two wheels up onto two 2"x14"x24" pressure treated boards. Then slide the low profile jack under the center of the cross beam, and jack from there. No boards.
