When I picked up a new set of wheels and tires a couple years ago, I forgot to take my TPMS sensors out of the old wheels.
Now that I'm replacing my rear tires (fronts where replaced recently because of a flat, didnt have time to order sensors) I just went ahead and ordered 2 sensors/nuts from GMPartsDirect.
The reason I'm posting this thread; is it possible to program ONLY the rear sensors?
Looking at the procedure for reprogramming, the front tires need to be done first.
Is there a way to skip them in the procedure? Or should I just do the rear tires twice?
You will need to go through the sequence and re-program all 4
