Lowering with F45
Old Jan 21, 2010 | 02:44 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Lowering with F45
I am thinking of lowering my 01 coupe. I actually have two questions, the first is I have heard that it is not a good idea if you have the F45 Selective Ride Suspension, because it will cause codes to be displayed. The second is I read somewhere that if the suspension is lowereed, that the steering bumps (I believe that was what it was called) need to be installed.
I am also planning to install the C6 Z51 sway bars front and rear in the next month or so, will that make any difference?
Old Jan 21, 2010 | 02:53 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
I am also planning to install the C6 Z51 roll bars front and rear in the next month or so, will that make any difference?
I think you are probably talking about sway bars, and no they will not make a difference on the lowering adjustment. Don't know about the F45 as I have the Z51
Old Jan 21, 2010 | 03:15 PM
FKING1's Avatar
FKING1
I lowered my 2000 F45 Coupe about 2" and ran that way for 8 years. No codes or any other changes made.
Only complaint was at 2" the shocks would bottom out on bumps.
Put on PFADT coilovers 2 yrs ago and am very happy with them.
Old Jan 21, 2010 | 04:36 PM
bdiddo's Avatar
bdiddo
Ran with mine (F45 Susp) for almost two years with no problems.
Old Jan 21, 2010 | 05:27 PM
Magred6sp's Avatar
Magred6sp
Good Question. I also have an 01 coupe with the F45. I have installed the C6 Z51 sways - nice improvement. I want to lower the back enough to match the front, it looks like the back is 1-2 inches higher. I just don't have the $ for a new alignment. Thanks for asking the question.
Looks like it should be OK........Good Luck.........Dave
Old Jan 21, 2010 | 09:41 PM
vvf-16's Avatar
vvf-16
Old Jan 21, 2010 | 11:28 PM
c5blkvetteguy's Avatar
c5blkvetteguy
If you are lowering your vette for better handling I would get rid of the F45 shocks and install some C6Z06 shocks. If it is just for the stance then leave the shocks on.
Old Jan 21, 2010 | 11:47 PM
JCamaro's Avatar
JCamaro
I lowered on the F45 last year. In order to avoid the "lumber wagon" ride over large bumps(this is actually the shocks stiffening up excessively to counteract what they believe to be an out of spec ride position) I did have to play around a bit with the ride height until I was satisfied with both the level of lowness and the ride quality/function of the F45. You will probably not be able to go Max on stock bolts...but pretty close.
Check out my garage I have a couple pics of where I'm sitting....and think about if that's far enough. If not...then I would recommend coilovers....then you can go as low as you want.
@ MagRed6SP......if you can't afford the alignment don't drop it.....cause you will almost certainly kill your tires...and they cost a buttload more than a W/A. Saving 60-100bucks will cost you a set of tires.
Old Jan 22, 2010 | 12:02 AM
napacruzerc5's Avatar
napacruzerc5
I have lowered my 2001 F45 coupe on the stock bolts. Front approx 3/4 inch and the rear 1/2 inch. Just enough rake to my taste. Also installed the C6 Z51 front sway bar and will eventually install the rear. No codes on the F45 from the lowering and have had very positive autocross results with the sway bar exchange on a typical autocross course. I'm running stock sized Kumho MX tires on the stock polished wheels and I feel the vette is well balanced with this setup. Adding the rear Z51 sway bar may induce more oversteer especially on the Kumhos which have nowhere near the stick of the Hoosiers or other "R" type tires.
Old Jan 22, 2010 | 12:36 AM
dobewillie's Avatar
dobewillie
Lots of great info thanks posters
Old Jan 22, 2010 | 12:59 AM
Indy's Avatar
Indy
Had my F45 fully lowered (including cut bushings) for over a year without any codes. And yes, the shocks will firm up a lot
To Lowering with F45
