Ran over a dead deer
Old Jan 23, 2010 | 10:45 AM
frankb's Avatar
frankb
Default Ran over a dead deer
Early morning, dark and I swerved around the best I could at the time. The front tire ran over some part of it. As it did the the car came off the ground on the passengers side. Luckly only a small crack infront of the tire on the nose. The other day getting on the highway I started to go through the gears. The front passengers tire started to bounce so bad I had to slow down. I tried to check the search but came up with nothing. The speed was just at tripple didget. Did I break something? Thanks for the help
Old Jan 23, 2010 | 10:55 AM
RSchleder's Avatar
RSchleder
Sounds like some significant suspension damage to me plus things are probably out of alignment. Front end shop should be on your "radar" very soon! Good luck, Ron
Old Jan 23, 2010 | 10:58 AM
BlueDragon's Avatar
BlueDragon
It is possiable that you bent something, or just knocked the front end out of alignment. Due to speed sensativity, might be a simple as loosing a wheel weight. Sounds like it is time for a full alignment and balance job.
A while back I hit a pretty good sized dead animal laying in the road similiar to you. It was smaller than a deer but bigger than a dog or racoon. I had just enough time to center up on it and it made a hell of a mess but that was all.
Old Jan 23, 2010 | 11:03 AM
KSUPROF's Avatar
KSUPROF
Sorry to hear about this.
I have lived in KS for 20 years and have hit 4 deer with my pickups and one van during that time. I don't drive my Vette at night for this very reason.
I wish the state would get serious about significantly reducing the deer population. There are too many.
Old Jan 23, 2010 | 11:33 AM
TheDingo's Avatar
TheDingo
I would have the alignment checked and wheels balanced. Check the passenger side wheels for any damage. Also, if you have the tools, check your shocks. That could also be causing the 'bouncing' sensation.
Old Jan 23, 2010 | 12:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Along with checking all the area under there, you might want to test the shock itself. That sudden hit might have caused it to fail internally.
Old Jan 23, 2010 | 12:46 PM
Omaha02Z06's Avatar
Omaha02Z06
Have you jacked up the car to inspect if anything is broke? I would start there. Might have broken some of the metal bands in the tire. That could be one of the causes of the bouncing.
Old Jan 23, 2010 | 04:56 PM
vvf-16's Avatar
vvf-16
I ran into a wheel /tire assy sitting in my lane on an On Ramp, also going through the gears at the time with my 81 awhile back, blew the tire and bent the rim, - showed up at speed.
Old Jan 23, 2010 | 06:32 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Time to take it to the shop and have it inspected - It could be something bent or a busted shock etc.
Jack it up and remove the wheel and see if you can see any visable damage yourself and spin the wheel to see if it is wobbling or if you lost thw wheel weights!
Should not be too hard to find and fix
Thanks,Matt
Old Jan 23, 2010 | 07:15 PM
dobewillie's Avatar
dobewillie
Good luck with getting your car squared away
Old Jan 23, 2010 | 08:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Get your Vette in the shop ASAP and make sure all is ok or get a repair
Old Jan 23, 2010 | 09:09 PM
Good luck finding out the source of the bounce.
Old Jan 23, 2010 | 11:04 PM
Race Prepared's Avatar
Race Prepared
Did you have a license to hunt that deer?
Old Jan 23, 2010 | 11:43 PM
vette.mix's Avatar
vette.mix
Old Jan 24, 2010 | 09:42 AM
frankb's Avatar
frankb
Thanks for the reply. I did get under and look for damage and I couldn't see anything out of place. I guess off to get a balancining and all. I was going to take it home and cook it but I didn't know what part was mine.Again thanks for the help. I follow you guys but I'm the one who knows very little compaired to you all.
To Ran over a dead deer
