Tire Pressure Sensor Cost
Jan 24, 2010 | 07:49 AM
My Local Dealer That I Don't Trust Said The Cost Of The Sensor For Right Front Side Is $190.00....Does This Sound Like The Right Price ? Thanks
Jan 24, 2010 | 07:55 AM
Oldtimer
Quote:
Originally Posted by
jetboat1978
I'm ordering new rims with tire pressure sensors for my TrailBlazer SS and it's $200 for all four. I can check with my son, he's a service writer at a Chevrolet dealership.
Jan 24, 2010 | 08:02 AM
it sounds a little high but the senor alone is $95-120 ea new.
I bought a used set on ebay and replaced the batteries
Scott
Jan 24, 2010 | 08:19 AM
It's probably the battery that is bad. Do a search and there are posts on replacing them.
Jan 24, 2010 | 09:15 AM
I believe the batterys are only replaceable on the early sensors (1997 - 2000) and even then it may not be something you can do your self.
Here's a copy the prices from Gene Culley's GM Parts house one on the Forum sponsors.
2001-2004 Sensors
25773946 - sensor – 40.19 each
15234846 - nuts – 3.73 each
Total setup of 4 is 192.90 shipped
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
1997-2000 Sensors
25981210 - sensor – 94.20 each
Total setup of 4 is 430.11 shipped
Jan 24, 2010 | 09:21 AM
No that is too much check with GM parts house a forum vendor
http://www.gmpartshouse.com/ thats where I got mine. Their are 2 different types I have a 97 that is the more expensive of the 2 and it was still cheaper than that.
Jan 24, 2010 | 11:14 AM
Thanks Guy's You All Are Great !
Jan 24, 2010 | 11:17 AM
Oldtimer
I checked with my son and he has no idea. I think he said that because I woke him up.
Jan 24, 2010 | 11:24 AM
Just installed new tires and wheels. Discount Tire charged $30 to re-build my old sensors.
Jan 24, 2010 | 11:32 AM
Silver48
I think if you were to check closely that "rebuild" is actually just a new exterior nut, valve stem, cap and perhaps an o'ring if you have the old style sensors (new style does not have a serviceable o'ring). I had them want to do that when I put new rear tires on and I declined the extra expense ( $7.50 per wheel).
Jan 24, 2010 | 01:52 PM
5th Gear
Tpms cost
The sensor thrugh CarQuest is about $40.00 and about $3.00 for the service kit (nut o ring, shrader valve, cap and nut).
Jan 24, 2010 | 03:19 PM
That's insane - Get them from Gene at gmparthouse.com and save a ton of money.
Jan 26, 2010 | 08:32 PM
Premium Supporting Vendor
Thanks for your referrals and votes of confidence. I would certainly be happy to help out.
