Dealer just cannot fix problem, what next ???
Old Jan 25, 2010 | 11:20 AM
lone73's Avatar
lone73
Default Dealer just cannot fix problem, what next ???
I have an '04 vette that has been in to the dealer for service about 6 or 7 times for chronic - traction control / active handling / abs - errors. They've replaced some wiring, replaced one computer and some other stuff, all to no avail. The code always points to the RF wheel sensor.
This is consuming much of my free time dealing with this. In this latest round I picked the car up last Tuesday, drove it to Dallas from Austin and on the way home the lights came on again - same errors.
The extended warranty went out 3 repair attempts back. I'm stuck in an endless loop here. I was about to call the dealer yet again and see what they want to do about it (if anything) but I figured I should ask here as well and see if someone has ever had similar issues and how it was resolved.
Is there any other recourse I can get from GM? What do you do about a problem that the dealer just cannot fix?
Old Jan 25, 2010 | 11:25 AM
kornfreak_401's Avatar
kornfreak_401
sounds like they may just be reseting the lights. they need to replace the abs module. $700 or so... thats why they dont want to "fix" it lol
J
Old Jan 25, 2010 | 11:29 AM
corvettebob1's Avatar
corvettebob1
May be a dumb question, but has the RF sensor been checked or replaced?
Old Jan 25, 2010 | 11:44 AM
lone73's Avatar
lone73
Yes, the RF sensor was the first thing replaced. I think the service writer told me they replaced the traction control module about 3 repairs back.
thanks
Old Jan 25, 2010 | 11:52 AM
itzza427's Avatar
itzza427
The EBCM is the computer system that is in control of the system you are referring to. There is a braking system unite attached to it. There are wheel sensors tied in from all 4 wheels. Lots of places for shorts or malfunctions. There is even a ground junction close by on the frame where several ground wires meet close to the EBCM,,and there have been cases where the connection or the mounting point had corrosion and caused problems. You need a shop that specializes(or at least has a good % of corvette business) to trace all the lines for shorts,,track all the grounds and narrow it down to the computer,system pump or whatever!! It is VERY common for dealerships to NOT have a corvette savvy mechanic!! If it is going to be a warranty situation,,you will need to find a dealer that sells/services a number of Corvettes!! Hope this helps!!,,,,,,Jus t noticed you are in Texas. Don't know exactly where you are,,but Corvettes of Huston and Corvettes of Dallas(business partners) are 2 WELL known vette places !!
Old Jan 25, 2010 | 12:26 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
And your warranty should still cover this,, as long as the dealer/service writer admit they have not fixed it yet.
Old Jan 25, 2010 | 12:55 PM
Corvettes of Dallas's Avatar
Corvettes of Dallas
I would hope that with 21 years experience of just working on Corvettes and currently over "150 man years" of Corvette experience -- we can get you back on the road without codes. Please give me a call direct so we can assist and reduce your frustration level. If you do come to Corvettes of Dallas -- please make sure to bring all of the previous work orders so we can see what has been done -- it will help us trace the failure.
Todd
Old Jan 25, 2010 | 01:09 PM
garage-ghost's Avatar
garage-ghost
Lemon Law
http://www.carlemon.com/lemon/TX_law.html
Old Jan 25, 2010 | 01:18 PM
Jet-Jock's Avatar
Jet-Jock
Hmm no mention of replacing the ABS module. When mine started spewing codes, GMPP replaced both the EBCM and the ABS module.
Old Jan 25, 2010 | 01:33 PM
AU N EGL's Avatar
AU N EGL
I am guessing the right rear bearing is shot .
On the track we see ABS codes right before the bearing goes out. and No it does not show up in the codes.
Old Jan 25, 2010 | 04:37 PM
Dominic Toretto's Avatar
Dominic Toretto
Haven't experienced this issue myself but, I would recommend giving Todd or Jeff a call at Corvettes of Dallas. I take my car there regularly for service and am always satisfied. Great bunch out there. Definitely would not hurt to call them at least. Good luck.
-Alex
Old Jan 25, 2010 | 05:42 PM
PUMP03's Avatar
PUMP03
Oldtimer
I recommend that you read the following post by Bill Curlee regarding chassis grounding points. Poor ground connections can cause false codes.
http://forums.corvetteforum.com/c5-t...tion-long.html
Old Jan 25, 2010 | 06:21 PM
Lancejoker's Avatar
Lancejoker
Just curious,do you have LED tail lights? If you do,the quality may not be good and you may have issues with that light coming on. As someone else said,it is tied into the braking system inlcuding the lights.
Old Jan 25, 2010 | 09:43 PM
lone73's Avatar
lone73
Took it back in to the dealer. They are willing to take another look at it next week. If that doesn't get it fixed I might take Todd up on his offer at Corvettes of Dallas.
Pump03: The service manager said today he had already been thru all the grounding points... although that doesn't necessarily eliminate grounding as the issue.
LanceJoker: I don't have LED tail lights.
Jbondfl: It was covering it, apparently up until today. They were giving me a rent car on GM's dime. Today the dealer was covering it so I'm guessing they're not going back to GM for whatever reason.
Thanks for all the replies
Old Jan 25, 2010 | 10:15 PM
I can only imagine how frustrating this must be - hope you get it figured out soon and put this problem behind you.
Old Jan 25, 2010 | 10:30 PM
Lancejoker's Avatar
Lancejoker
Are there any constants like water or something when it trips?
Old Jan 25, 2010 | 10:49 PM
lone73's Avatar
lone73
Jack: Thanks, me too...
Joker: No it doesn't seem like anything in particular induces the error. It might happen right after hitting a bump or just cruising down a smooth interstate at 70mph. I've hit some deep water at 60 too - no errors, in fact it's never errored out during rain.
thanks
Old Jan 26, 2010 | 01:19 AM
Choreo's Avatar
Choreo
So what code numbers show in the DIC when you run diagnostics?
Old Jan 26, 2010 | 03:42 AM
JerG's Avatar
JerG
What codes are tripped? The codes specify the exact wheel that's the problem. The sensor and hub/wheel bearing are one unit, that was replaced on my 99 but I was still
throwing codes for the same wheel. It turned out to be the wiring harness for that wheel to the computer that was bad.
Jerry
To Dealer just cannot fix problem, what next ???
