front splitters....question
ACP
There are several
mine is an overlay splitter. It Overlays the lower part of the front facia
and I installed a front diffuser under the car
Have 2" of ground clearance.
Car is a front not a bottom breather
The splitter sticks out 2" in front of the nose of the car.
with a 2" splitter, the rear NEED a 1" rear spoiler point up at 45* to help balance the car. Plus rake adjustments.
Down side, Not for street use. I would hit every dead thing on the road.
next are the detachable 4" front splitters. It can detach from the front facia.
Notice on both cars the radiator opening is 5" high by at least 18" wide.
the 4" spitter ,must have an extractor hood and a 72" rear wing to balance the car
Here are the list of parts, no pics
http://www.corvetteracebodies.com/wo...ice%20list.htm
Do this produce downforce? YES a LOT of downforce. Need very stiff suppension to hold the car UP at speed
a 1" spoiler at 45 degrees is all you need? I wouldnt think that little bit would do anything
http://forums.corvetteforum.com/c5-p...-300-00-a.html
Check out this thread in the FS section:
http://forums.corvetteforum.com/c5-p...-splitter.html
909 594 3796 or emailing at sales@aprperformance.com
Yes Sir,
She's having her paint touched up.
[/QUOTE]
She's a beauty. My dad use to have 2 at the same time.
But back onto the topic at hand....
If you wanted to build one out of aluminum, ss, cf or any other material you could build it then have the strut brackets added.
