ignition bezel cracked
Jan 30, 2010 | 12:20 PM
the black bezel around my ignition has a large crack in it. Where can I get a new one without spending an arm and a leg? also, has anyone seen them in anything else but black?
Jan 30, 2010 | 01:31 PM
Gene Culley
www.gmpartshouse.com for new
check the C5 parts for sale section, there is usually some onme parting out a C5 . Generally their prices are lower than a Corvette specialty recycle shop...
Jan 30, 2010 | 03:20 PM
Not really your question, but if it is just cracked, or cleanly broken, you could get some glue or body-filler, work it back to shape and just paint it. If you are anywhere near careful you can make it so there is no sign of a repair.
Just a suggestion......and some fun as well. I love DIY projects
Jan 30, 2010 | 03:24 PM
Its a cheap part. The only problem is you need to take the console out to replace it.
I refurbished my old one using milliput when it cracked but I now have a new one waiting to go on.
There's a black wire attached to the part that needs unclipping and refitting on the new one so be careful as you pull the dash
Try the Vette Essentials website for how to do that
http://www.vetteessentials.com/instr...brake_h_b.html
Jan 30, 2010 | 04:21 PM
St. Jude Donor '12-'13
look for a product called Q Bond
put the stuff on the back side
put a little filler on the front
spray with a flat black paint
your all set
pm me if you need any more info
you will need to take out the bezel as well
Jan 30, 2010 | 09:41 PM
I think I paid $12 for it from Gene.
Jan 31, 2010 | 03:24 PM
I had to get a quote for this part recently as well. Gene Culley said it was $14.08. Part number: 2852046
Feb 3, 2010 | 11:44 PM
Premium Supporting Vendor
Thanks for the referrals. Good info given here. All you need to do is go to
www.gmpartshouse.com/search.html and use part number 2852046.
Feb 4, 2010 | 08:51 AM
2003 ,
bezel ,
c5 ,
california ,
corvette ,
ignition ,
number ,
part ,
replace ,
replacing ,
zo6
