code U1232 afer battery swap
Old Jan 31, 2010 | 01:36 PM
C5Bagger's Avatar
C5Bagger
Default code U1232 afer battery swap
I posted this in Tech also, This problem started last fall before she went down for her long winter nap, howerver I know it wont fix itself and hopefully spring is coming so I thought I'd try again.
Replaced my original battery with a Die Hard Platinum, in doing so I heard popping coming from what sounded like under the right headlight. the ABS/ TCS and DIC trouble light showed on the dash,Codes C1283, U1000, U1064 and U1232 were all cleared except U1232 (LF wheel speed sensor circuit open or shorted) which is still there along with dash lights. Does anyone know what I may have screwed up?
