hood liner cleaning
Old Feb 2, 2010 | 09:05 PM
fireman591's Avatar
fireman591
Originally Posted by nadj99
Where'd you guys get those chrome plugs to hold up the liner?
Lowes They are faucet plugs for a sink
Old Feb 2, 2010 | 10:56 PM
nadj99's Avatar
nadj99
Very cool I thought I saw H and C on there. I thought they were your initials
Going to get some tomorrow
Old Feb 3, 2010 | 09:11 AM
RDKING's Avatar
RDKING
Originally Posted by rws.1
I would never brush the hood liner...
Spray it with a good degreaser... I use 3 parts water, 1 part Simple greeen. let it soak for 5 minutes... the rinse...
i use the broadest setting on my power washer, but you could use a garden hose...
Keep the hood up to let it drip dry and then let it eaither dry in the sun or close the hood and go for a long drive so the engine heat dries it...
Once dry. remove and spray paint with several LIGHT coats of rusoleum flat balck BBQ paint.
Old Feb 3, 2010 | 09:41 AM
dieseldave56's Avatar
dieseldave56
Default cleaning hood pad .........
I soaked mine in an old kids blowup pool, using TSP and warm water. Let it set a day or two. Lightly spray off the Pad as it sits horizonal on some plastic lattise. Wait till completely dry.
Oh I use an upholstery tack remover to remove the black push pins.
Then I used matte black paint ( flat does not look correct and gloss does not either in my opinion) to spray.
I also installed the C5 logo ( vinyl) emblem (got it off Ebay $24). I then masked off around the logo emblem and sprayed a polyurethane clear coat over the logo. This makes it easy to clean and also ensures the adhersion of the logo.
Using new OEM push retainers ( again EBay, 25 for $7) just attach it to the hood.
Old Feb 3, 2010 | 11:16 AM
AntonioZ06's Avatar
AntonioZ06
any suggestions on brand or kinds of paint? This is definitely something I want to try out while the car is being stored.
Old Feb 3, 2010 | 11:25 AM
DeeGee's Avatar
DeeGee
I used BBQ paint from Home Depot
Old Nov 22, 2010 | 01:19 PM
coajam's Avatar
coajam
I noticed that a lot of the pics showed a C5 decal under the hood. I tried that also and I followed the instructions but the decal still flaked off. Any suggestions?
Old Nov 22, 2010 | 04:27 PM
JerG's Avatar
JerG
My hood liner was showing it's age. I decided to paint it with some Kyrlon Blk BBQ paint
($5)...it came out really nice. Was very surprised how nice the embossed logo looked with just a re-paint, I decided I didn't even want to do a decal on it. Broke a couple of the plugs but found some at NAPA.
Old Nov 22, 2010 | 05:19 PM
ricknyc23's Avatar
ricknyc23
I cleaned mine with armour all tire foam as suggested by other memmbers. It worked great!
Old Nov 22, 2010 | 05:49 PM
vafirevet's Avatar
vafirevet
Amour All Tire Foam works wonders! You don't even have to remove it from the hood.
Old Nov 22, 2010 | 07:14 PM
RedSoxFan's Avatar
RedSoxFan
This worked great for me also, I forget which forum member first posted about using Amor All tire foam on the hood liner but thank you! I tried it this past summer and it worked like a charm.
Old Nov 22, 2010 | 10:02 PM
O4-/-C5's Avatar
O4-/-C5
What is the application method?
Old Nov 23, 2010 | 08:12 AM
  #33
Randyman2002's Avatar
Randyman2002
How well is the logo installation holding up?
Old Nov 23, 2010 | 11:15 AM
  #34
vafirevet's Avatar
vafirevet
I put a bed sheet as an over spray cover over the motor and fenders and sprayed it from the can that Armour All Tire Foam comes in. The black tire foam evaperates and leaves a clean black surface on the hoodliner. No scrubbing or mess. Then pull off the bed sheet and enjoy your work.
Old Jun 18, 2013 | 08:14 AM
  #35
toblue02's Avatar
toblue02
sprayed mine with one step tire cleaner,seemed to clean it up very easy, give it a try.
