Question using dielectric grease
Old Feb 2, 2010 | 07:35 AM
avettelovertu's Avatar
avettelovertu
Default Question using dielectric grease
Recently I lubed my weatherstripping with dielectric grease. I noticed its properties feel much like petroleum jelly a.k.a vaseline. Now the question. My refrigerator manual said to keep the seals in good condition, a person could apply a small amount of petroleum jelly to them. Could this be done with weatherstriping on a car? Just asking after you quit laughing.
Old Feb 2, 2010 | 08:03 AM
RSchleder's Avatar
RSchleder
It would probably work, however, I think it would collect a lot of dirt as it remains "sticky"
Old Feb 2, 2010 | 11:03 AM
ALLEGRO's Avatar
ALLEGRO
I use it in the cooler months. It works very well. BUT, in hot weather it just melts away.
Old Feb 2, 2010 | 11:18 AM
joshtownsend's Avatar
joshtownsend
Dielectric grease was designed to conducted electricy and remain outdoors.. unless you keep your car indoors all the time, other grease will fade away quickly.
Old Feb 2, 2010 | 11:48 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
had a friend whos car doors kept getting frozen shut, put vaseline on the weatherstripping and never had another problem
Old Feb 2, 2010 | 12:46 PM
EZEDDIE's Avatar
EZEDDIE
I apply dielectric grease twice a year on all wheater stripping. Works like a charm! It lasts a long time and keeps the weather stripping moist and plyable. MY vette is 9 yrs old and the weather stripping is in perfect shape. Why mess with a good thing? Save the vasaline for other things.
Old Feb 2, 2010 | 02:10 PM
Last C5's Avatar
Last C5
We used to use dielectric grease on the panel tops of the C3s to keep them from squeeking. It worked OK, but you did have a little dust to wipe off, especially if you put it on a little too thick.
Old Feb 2, 2010 | 02:13 PM
tony car4a's Avatar
tony car4a
Years ago I actually took the time to read this: "Never let a latex condom touch oil in any form, such as petroleum jelly, baby oil, mineral oil and vegetable oil. Oil rots rubber." and decided not to use vaseline on weatherstriping. I use dieelectric grease and/or 303 Aerospace (on my cars).
Old Feb 2, 2010 | 02:36 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
good discussion guys
I use GM's 'emulsifier' for my seals. any thoughts as to which is better-dielectric or the gm stuff?
Old Feb 2, 2010 | 03:10 PM
SSTG's Avatar
SSTG
I use Gummi pflege from 1Z. No steaking,no dust collecting and it goes on easy to boot.
Old Feb 2, 2010 | 03:35 PM
DeeGee's Avatar
DeeGee
Not sure; I use dielectric grease.
Old Feb 2, 2010 | 06:17 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
You might want to Google that.
http://www.wisegeek.com/what-is-dielectric-grease.htm
http://en.wikipedia.org/wiki/Dielectric
Dielectric grease is used to help seal electrical connections against water, dirt, etc. It depends on the contacts actually scraping enough grease off the contacts to complete the circuit.
Old Feb 2, 2010 | 06:22 PM
cedge's Avatar
cedge
Old Feb 2, 2010 | 07:37 PM
mcgilles's Avatar
mcgilles
yep, dialectic grease itself doesn't conduct electricity. if it did it would short out every connector you put it in!
Old Feb 2, 2010 | 10:48 PM
Choreo's Avatar
Choreo
So are you saying if I use a condom I should only use it with Dielectric Grease?
On second thought, I don't think that based upon past performances mine would have enough exposure time to "rot".
Old Feb 2, 2010 | 11:14 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I use Dielectric Grease from NAPA on all of my vehicles and highly recommend it......
Old Feb 2, 2010 | 11:17 PM
Exoray's Avatar
Exoray
Oil rots rubber."
Way to broad of a statement, to be factual... Some oils and some rubbers get along just fine while others don't...
Jump to the C6 forum as this has been discused there...
http://forums.corvetteforum.com/c6-c...intenance.html
To Question using dielectric grease
Old Feb 2, 2010 | 11:49 PM
It may work, but I'll stick with dielectric grease.
Old Feb 3, 2010 | 01:45 AM
itzza427's Avatar
itzza427
Don't laugh,,heard PAM works well on weather striping! Must admit,,I have not tried it,,so far I've only used dielectric as well!! Might try it on my truck to see!!
Old Feb 3, 2010 | 09:07 AM
dieseldave56's Avatar
dieseldave56
Default dielectric grease application........
Dielectric grease is silicone based & it used as a insulator, keeps out moisture and also is a electrical componet lube. I use it sparingly on all electrical connections, including the plug boots. It can be used on "rubber ' components ( according to my Permatex box) without fear. Dielectric grease does not conduct current, if fact just the opposite it prevent voltage leaks around connections. But as others also point out, it will attract dirt, ect.
I have always used AeroSpace 303 UV protectant to clean and protect all " rubber "component parts. 303 is the safest tire sidewall protection product as well.
